Yes. I literally just installed tow mirrors on my 24' Wednesday night. It hasn't even left the driveway. I just went out to my driveway and yes that's exactly how the OEM lights work. I would of thought the entire led marker light would flash.I'm confused by the first video. Is that only partially working? I see blinking but only on the back side.
There is a setting in forscan to activate this. It did not work on my 22 so I bought the harness from boost auto. It’s the harness not lenses like previous link posted here.Yes. I literally just installed tow mirrors on my 24' Wednesday night. It hasn't even left the driveway. I just went out to my driveway and yes that's exactly how the OEM lights work. I would of thought the entire led marker light would flash.
Good to know. Thanks for the heads up. I'll have to check this out.There is a setting in forscan to activate this. It did not work on my 22 so I bought the harness from boost auto. It’s the harness not lenses like previous link posted here.
This is the kit from boostauto for my 22Good to know. Thanks for the heads up. I'll have to check this out.
Where do these plug-in at?This is the kit from boostauto for my 22
Wow that is crazy design. Standard mirrors here so I assumed it would light the whole strip in the same way.Yes. I literally just installed tow mirrors on my 24' Wednesday night. It hasn't even left the driveway. I just went out to my driveway and yes that's exactly how the OEM lights work. I would of thought the entire led marker light would flash.
You pull the triangle trim on the door and splice this into the harness. Very easy. There’s a video on it on boost autoWhere do these plug-in at?
Fantastic! Thank you.You pull the triangle trim on the door and splice this into the harness. Very easy. There’s a video on it on boost auto
