STX fog light install
jhelrey
MN
Why is everyone removing the grill to remove the front bumper? It's not necessary. Remove the plastic trim piece above the steel bumper. Disconnect wiring lying underneath the truck on passenger side under the frame horn. Remove the 6 bolts. Remove the bumper.
If you are remotely handy with common mechanic tools, it's easy.
Dick
Newfoundland, canada
2022 f150 stx
Yes, that is actually true the grill doesn’t have to be removed. But removing it( which is the easiest part of the install) gives you more room for the top bumper bolts. Only a handful of clips holding it in. Same end result.
FAILWISH
Jim jim
Tx
F150 xl 150 supercharger/f150 xl 5.0
Maintenance tech
All you gotta do is remove plastic loom from the extension harness and solder fog light connector to it. Then unplug factory plug from headlight and plug it into one end of extension harness and then plug the other end back into the headlight and that’s it. Works perfect and you won’t have turn your fogs on every time as they will come on with your headlights. Hope this was helpful.
Are you using this connection as the relay signal to start the figs with reg low beams? To the wiring from headlights?
