Turbine noise??? I don't think there is a turbine in it. At least there isn't one in mine. Are you talking about the noise it has to make, by law, because it is an electric vehicle.Seeing as some have experienced situation where too much torque was being sent by the electric motor and throwing codes, I can only imagine that a tune on PB will be much more complex then your usual tune.
I am quite satisfied with the power levels of my PBI do wish for two things however:
- Hear more turbine noise
- Stay longer in electric mode before kicking in the ICE, it feels that the electric motor has much more to give.
The noise from the compressor (cold) side of both turbosTurbine noise??? I don't think there is a turbine in it. At least there isn't one in mine. Are you talking about the noise it has to make, by law, because it is an electric vehicle.
You have to remember that the electric motor is tiny to say the least. If it can't maintain throttle demand with its puny 44 HP electric motor, it kicks the gas engine in. This thing is a hybrid in name only. There is no way it is anywhere close to any other hybrid I'm familiar with. Even my wife's Fusion has an electric motor that is over 100 hp which handles highway speeds without any issues. Be satisfied with the fact that you have a "one off" hybrid vehicle, some day it will be a collector's item. I'm only keeping mine until something better comes along and its NOT the Lightning. My only wish I have, is getting rid of the backup alarm... this is a pickup, not a fork lift!
Are you sure that the battery is 500 lbs?They already have a 500lb battery down there, essentially taking that much weight straight off the payload capacity of the truck; just imagine doubling that and losing that much more capacity. It would require some rework of the whole truck's design to accommodate anything bigger (Like they had to do on the Lightning), and that's probably just not something they wanted to deal with for this first generation of hybrid.
It's not, you're right. The total weight difference of all the extra systems from PowerBoost (Hybrid transmission, generator, battery, supporting systems) total a 500lb difference between a standard 3.5L EB.Are you sure that the battery is 500 lbs?
This is my ebike and it has a 630Wh Bosch Li-Ion battery that weighs around 6 lbs and fits in the down tube. I have a buddy that carries a spare battery in his backpack for 1.26kWh of power on long rides.
I doubt the PowerBoost battery is all that heavy.
There is a heat exchanger in the exhaust. The one that keeps leaking.Somewhat on that thought, does anyone know if there’s any sort of magic to the heat on a PowerBoost? I thought I had read there wasn’t, and I know the engine will come on when you need heat and it’s cold, but my PowerBoost seems to somehow generate heat in about half the time my ‘15 3.5 EB did. Much quicker than my wife’s Explorer with the 2.4 EB as well (Just judging it on how far from home I get until I can feel good heat coming out of the vents).
Just feels like it gets heat coming out way quicker than any normal engine could, was wondering if there is any special heating elements running off the battery or something like that.
I bet we will see larger aftermarket batteries in a couple years.It's not, you're right. The total weight difference of all the extra systems from PowerBoost (Hybrid transmission, generator, battery, supporting systems) total a 500lb difference between a standard 3.5L EB.
