Still missing features - 2021 Job 1 XLT
dantheman68
Dan
Wisconsin
2021 F150 XLT 3.5TT 4x4
I have a job 1 2021 XLT that I bought back in early May and am missing at least 2 things that I think i should have based on my update level.
1. Cameras at speed (I tried the FORScan hack) but want the bed camera card on the right side so i can see my map while looking in the bed.
2. Pro Trailer Backup sticker function - I've got the stickers in my glovebox, but when i push the button it says "connect sensor" or something like that, giving no option for sticker use.
I'm currently on version 23291_product revision 1049 of sync and I am getting updates (just got a 10.1.1 update within the last week) so I think I am at the update where I should have both of these features even though I am behind on sync updates.
Do I need to go to the dealer at this point and pay even more money to get these features?
Is there anywhere else I can check other than sync version to see if maybe a module or BCM is behind in updates?
rugedraw
Javier
Miami
Auto Sales
I'm not sure about the pro-back up set up because I never did it on mine; not interested in that at all.
In regards to the bed camera: What exactly did you try with FORScan?
dantheman68
Dan
Wisconsin
Ford F-150 Still missing features - 2021 Job 1 XLT 1754414340386-lx
I did this from the forscan spreadsheet thread
OnefiddyXL3.3
J
New Brunswick
2021 XL 3.3 Screw
I made the same changes for camera at speed on my job 1 2021. It worked for about a minute and now I just get blue screen camera not available, see dealer. Camera works fine when backing up though.
I think I've got the same sync version as you and just got power update 6.1
rugedraw
Javier
Miami
Auto Sales
dantheman68
Dan
Wisconsin
I'm not sure then. I agree your Sync version is high enough where it should work.
I also noticed that my truck does not have the fake engine noises, which I don't want but I wonder if that means a previous owner previously modified the settings in Forscan and somehow disabled some things.
ETA: I will note that the camera at speed WORKS, I just don't have the "card" on the right side of the display where i can look at it while using the map, audio, etc.
rugedraw
Javier
Miami
Auto Sales
Yea, but I only two settings for the CHMSL camera in the APIM and the changes you made covered them both. I am not sure if there is a setting where you can modify what cards show up on the screen or not.
JIMFOUNTAIN
Jim
Austin, Tx
2021 F150 SCREW PB 6.5' 701A
You can turn cards off/on in the APIM at 7D0-03-01. Look for the IOD settings.
rugedraw
Javier
Miami
Auto Sales
dantheman68
Dan
Wisconsin
Excellent! Mine was E and I changed it to F to enable that card. The card appears but when i click the bed camera button it does not load and stays blank. One step closer
dantheman68
Dan
Wisconsin
Looking at 7D0-01-03 and the digit right before that I see this, highlighted is my option (3).
Ford F-150 Still missing features - 2021 Job 1 XLT 1754451227447-z
Is this my Pro Trailer backup sticker issue?
Should I try changing it to B?
rugedraw
Javier
Miami
Auto Sales
I would say yes. Mine is also set to 3. Seems like a B is correct there.
dantheman68
Dan
Wisconsin
I made the aforementioned changes, actually did A instead of B because I also read that sometimes the bed camera doesn't work if there are too many cards, so i removed the eco and eco behavior ones and the bed camera still does not work in the IOD view.
Ford F-150 Still missing features - 2021 Job 1 XLT 1754626403510-ai
I did a power cycle button off then on again and manually reset the apim with the power button and seek right button held down.
unixadm
Elk Grove, CA
2021 F150 XLT 5.0L Sport
Awesome! @dantheman68 check what you have here:
Thanks for this thread. I updated my 2021 XLT Job 1 truck yesterday which took about 10 hours using a VCM2. After everything was fully updated, I was missing the bed camera. In my prior 2021 F150 Platinum, it just started working after an APIM update, but in this truck, it was missing. I did not remove any pages (I have quite a few enabled stock), but I used this information to note that the setting from the factory was "E", and I changed it to "F". As soon as the APIM reset, the bed camera page was there and works fine. Again, thanks for posting this. It saved me a lot of hunting around.
rugedraw
Javier
Miami
Auto Sales
Glad I was able to be of help.
@aiderbooze I think this is the same issue yours has. Check my post that he quoted and see what your truck shows there in FORScan.
