Steering wheel phone button
FirstFord
South Central Missouri
Are you sure you changed the correct value? Did you also try rebooting the module?
Yes, and yes.
After the attempt, I had the wife give me a call, and everything appeared to be working as the mod should. Then she called again, and the second time the mod did not work. The first call I accepted the Sync was on the Android Auto screen (which seems to be the default screen), but the second call came in when Sync was on the Audio screen. I don't know if that makes any difference, but I just happened to notice it....
astrand1
astrand1
Alex
22 Ford F150 Powerboost 7.2kw
Studio truck driver
Yes, and yes.
That’s weird. Yeah once I changed that one value then the ipc stayed the same no matter what the sync screen was in I did not get the recall phone list on the ipc.
SilverPigeon
Australia
@FirstFord Jeff, what is your SYNC version? In the meantime, you can still hang up using the steering wheel button, then just hit the "back" button above it to exit the menu; don't have to take your eyes off the road that way.
FirstFord
Sync 4, Software Version 23291
Revision 1049
Interesting - another handy "work-around"
Yes, and yes.
I did check it - twice..... BUT I DO have dyslexia (seriously), so.... maybe I should recheck everything yet again....
