Steering Wheel Buttons not Working
Hamlet
Kevin
Winnipeg, Canada
2021 F150 Lariat 502A Sport, 2014 Chevy Camaro SS
Hoping someone can help me with a possible FORScan problem/solution. I was changing some of the simple settings via FORScan, like double honk on exit, bambi mode, power window pressure off (I have rain guards installed) and for some reason all the buttons on my steering wheel no longer work! I never adjusted anything on the steering wheel and returned everything back to normal but the steering wheel buttons still do not work.
Hoping to avoid a trip to the dealer if anyone can help.
tonesto7
Anthony
IT Admin | Software Developer
Certain IPC changes have done this to me. I can’t remember which ones.
Restore the factory IPC asbuilt and redo your changes 1 by 1
Hamlet
Hamlet
Kevin
Winnipeg, Canada
I restored the SCCM module to factory built settings and that fixed it. Weird but maybe someone else will benefit from my frustrations.
diambo4life
OKC
2022 Lariat Screw 4x4
Assassin
Mine did this to me as well. Trying to find out the fix.
balex
balex
Fuquay Varina
1969 Ford Bronco, 2023 Ford Tremor
This happened to me this morning. Was making some changes in Forscan and the steering wheel stopped working. I have tried to go back and change everything, still no dice. Was there any one setting that seemed to make it work?
DK4
Truck
Did you restore the SCCM back to factory to see if that worked?
Gary03l
Garibaldi
Oceanside, Ca
2022 F-150, 2003 Lightning, 1994 Lightning
Marine
My buttons stopped working also, with some other buttons from the dash after my center console/shifter install. I been trying to figure out this issue for a few days.
balex
balex
Fuquay Varina
I found the setting that hosed it for me. It was in the SCCM near the top. The Adaptive Light something or other. Switched that one back to what it was, and everything worked again.
I reset most everything, so I am going to try some of the settings again, but take better notes this time.
  • Like
Reactions: DK4
