Starter Struggling To Crank
Byrdman
Wisconsin
2021 F150 Lariat 5.0
I have a 2021 with the 5.0 and the other day, the starter seemed to have a really hard time cranking over the engine. It cranked for a tenth of a second and then stopped or stalled, then a few tenths of a second later it cranked until the engine started.
I made it home and once I was in the garage, I tried to start the truck five more times. Out of the five, it did it once more, the second time. I thought it was a dead battery but the other four times, it cranked like normal.
I originally thought that the battery didn't have enough juice but if that were the case, it would have struggled the remaining times.
Starter heat soak perhaps?
missileboy
MD
24 F150
I would definitely have the battery checked, it could be starting to fail. Heat soak could cause the starter to fail as well, but that usually take a few years. I would start with having the battery tested with a good scanner than has battery test module in it. crawl up underneath and look at the starter too and check all connections and grounds.
Ricksc
Rick
Bay area
I would start with battery. There was someone on here a while back that had the dealership tell him it was a starter. They changed starter same problem. It was the battery.
whosurpopi
Steve
2017 f150
Did you ever find out the problem? My 3.5 is doing the same thing.
unixadm
Elk Grove, CA
2021 F150 XLT 5.0L Sport
Testing the battery is aood idea. I have a professional grade Midtronics battery tester, but I also have one of those cheap 25 dollar testers from Amazon with the small screens. Usually they are pretty in parity when testing batteries, so if you have $20-30 kicking around, I'd recommend picking up one of those cheaper battery testers. They come in handy.
whosurpopi
Steve
2017 f150
I actually figured it out. The starter bolt had come just a little loose. I was able to give them a good tightening and haven't had the problem since.
