Graygoose2021
Yes i had a set for 21- up, so knew they had to have em or were on BO, all good sir.Thanks! The link I found on their website had an install video and a link that stated “coming in March. Preorder now!”
This is the kit I installed. $329 for front and back doors. Really good quality product.Their site lists the kit isn’t out yet? What was the price and what’s included in the kit?
I think without changing forscan or adding any insulation (mainly the front plates), differences will be minor. The factory eq really neuters the input signal for the crappy stock speakers.I have the non B&O 7 speaker system and installed the Kicker DS F&R speakers yesterday using THIS KIT OFF AMAZON in ~30 degree F weather and when I jumped in to hear it I must say I'm a bit underwhelmed. With it being winter out I just wanted to slap the speakers in so I didn't install any sound deadening or block off plates, just the speakers. I bumped the bass on my head unit and it may be a little better than the stock POS speakers, but not much. Is this more related to the brand new speakers being tight/new and the combination of cold temps? Or should I plan to dig back in and add more to the doors to get it to sound a little better?
Also, I had to elongate the hole for the speaker wire in the 6x9 adapter because the supplied pigtail/adapters were too short to reach the speaker terminals. I did not cover or seal this larger hole in the adapter. As many others on Amazon reported I also had to drill a new hole in the 6.5 adapter for the pigtail/adapter wire, which I also did not seal once the wire was through. Are these extra or larger air gaps that I created detrimental to bass response? Should the front of the speaker be isolated from the back of the speaker and "door cabinet" to the best of my abilities? Or does it not matter much?
What do you mean by "adding insulation", please? Do you have a pic of what this is and where it's installed? Thanks!I think without changing forscan or adding any insulation (mainly the front plates), differences will be minor. The factory eq really neuters the input signal for the crappy stock speakers.
As stated here https://www.f150gen14.com/forum/threads/speakers-best-bang-for-the-buck.12532/post-411966 on the outer door skins.What do you mean by "adding insulation", please? Do you have a pic of what this is and where it's installed? Thanks!
I jumped the gun on my comment out being underwhelmed. The Kicker DS speakers have broken in a lot over the last week and sound really damn good. Much better sound stage and detail. The mid bass is still lacking, so I'm going to invest in the block off plates and install/seal holes better,etc and tinker with those Forscan settings in warmer weather and I'll report back...I have the non B&O 7 speaker system and installed the Kicker DS F&R speakers yesterday using THIS KIT OFF AMAZON in ~30 degree F weather and when I jumped in to hear it I must say I'm a bit underwhelmed. With it being winter out I just wanted to slap the speakers in so I didn't install any sound deadening or block off plates, just the speakers. I bumped the bass on my head unit and it may be a little better than the stock POS speakers, but not much. Is this more related to the brand new speakers being tight/new and the combination of cold temps? Or should I plan to dig back in and add more to the doors to get it to sound a little better?
Start with the Forscan settings and that should make a noticeable difference. If you are still not satisfied, the blockoff plates will likely get you where you want to be.I jumped the gun on my comment out being underwhelmed. The Kicker DS speakers have broken in a lot over the last week and sound really damn good. Much better sound stage and detail. The mid bass is still lacking, so I'm going to invest in the block off plates and install/seal holes better,etc and tinker with those Forscan settings in warmer weather and I'll report back...
Made these Forscan changes today and ended up leaving #3 (ACM 727-01-01) as ***9 29*** because I liked it a little better than ***A 15**. Just wanted to say THANK YOU for providing this information. I have ~$200 into my system (Kicker DS all around) and it sounds $1,000+ better than stock. What a steal!Forscan:
I HIGHLY recommend these if you put new speakers in. These are ONLY for the 6&7 speaker NON B&0 stereos.
1. Send Flat signal to speakers (see previous post)
- Change ACM 727-01-02 ***0 ****
2. Reduce chime volume
- In IPC Module Configuration, change "Chimes - Primary Source" to "Instrument Cluster Only"
3. Change Speaker roles in ACM for best performance. (See my post for other options):
- Change ACM 727-01-01: ***A 15*
You were right. Thanks!Start with the Forscan settings and that should make a noticeable difference. If you are still not satisfied, the blockoff plates will likely get you where you want to be.
A little confused by this... is setting #1 ideal for those who have a subwoofer then? And #2 is best for those without a sub? Is there a reason you would not want full range to rears?Sure. I also sent this PM to a fellow member who had the 7 speaker system :
Go into ACM and pick one (or try each) of the following configurations for 727-01-01 based on your preferences:
1. ACM 727-01-01: ***A 15** (for deeper, smoother sound, full range only to front speakers, full range dash speaker)
- sounds great with rear fade. I run this currently
2. ACM 727-01-01 to ***9 29** (for bright sound, full range front and rears, tweeter only for dash speaker)
- sounds great with slight front fade, I ran this for a while but I prefer deeper sound.
3. ACM 727-01-01 to ***9 15** (full range to front only, tweeter-only for dash speaker)
- I have not tried this one, but you could try it out.
MAKE SURE YOU'RE Battery is charged (or done a 15m + drive) before doing any forscan changes if you're not hooked up to a charger. AND save your previous configuration to mitigate any bad writes.
Different strokes I guess and I do have a sub. It's all preference those are just some easy options I put up.A little confused by this... is setting #1 ideal for those who have a subwoofer then? And #2 is best for those without a sub? Is there a reason you would not want full range to rears?
Also, I can't stand the chime noise coming from behind the dash. Is the only drawback of leaving it stock the chime is slightly louder through the speakers and the pre collision alarm being super loud? Anything else to be aware of leaving it stock?
I actually disabled the startup chimes altogether (key In Ignition) and I barely ever chimes much anyways now.A little confused by this... is setting #1 ideal for those who have a subwoofer then? And #2 is best for those without a sub? Is there a reason you would not want full range to rears?
