diambo4life
Drop shackles only. Maxtrac.
What shackles did you use? Did you use any pinion shims?2inch rear drop shackles w/ Vossen rims and Michelin defenders 305/45r22
Did it create any vibrations?Drop shackles only. Maxtrac.
I think the shackles were belltech. I had a local shop do them. They also had to cut a support rail for the bed to clear room for the shackle. I attached a couple pictures. No shims used and no vibrations but the ride quality is sacrificed a little, and I do mean a little.What shackles did you use? Did you use any pinion shims?
@motivology figure out what your corner weight is. That would be a start on figuring out what spring rate you need.I am looking into getting leveling coil-overs set up for my truck with 3.0L Powerstroke and do wheels with AT tires. Apparently it's trickier due to diesel engine - from my understanding, it requires higher spring rate because it's a heavier engine.
Well known local truck shop said it's a bit of a guessing game because diesel F150 are not as popular.
Any advice? I was looking at Fox / Kings / Icons. Not looking to do pucks.
-DK
How do I figure that out? A member commented on a different thread I started stated this… is that what you’re talking about? If you scroll up a couple posts, you’ll see my specs.@motivology figure out what your corner weight is. That would be a start on figuring out what spring rate you need.
Snap ring coilovers… never heard of this, what exactly is that? Do you have a link to that?If you go with snap ring coilovers that re-use your factory springs that’ll probably give you the most accurate lift
requires that you disassemble and re-use your factory springs and top hats but that also makes this option very affordableHow do I figure that out? A member commented on a different thread I started stated this… is that what you’re talking about? If you scroll up a couple posts, you’ll see my specs.
https://www.f150gen14.com/forum/thr...ding-suspension-need-advice.20261/post-391478
-DK
I appreciate you. I am debating if I want to do reservoirs or not.requires that you disassemble and re-use your factory springs and top hats but that also makes this option very affordable
https://www.stage3motorsports.com/21f1504wd-21-22-f150-4wd-bilstein-5100-complete-shock-kit.html
https://www.stage3motorsports.com/fox21stage04wd-21-23-f150-4wd-fox-stage-0-package.html
Looks amazing. What setting did you put your front coils to? Did you increase it more than it came from the factory?Funny you should ask. Just finished installing an Eibach Pro Truck Stage 2R. I love the stance and the ride is noticably better than stock. Now for some new shoes.![]()
I'm still adjusted to the Eibach factory setting. Looking for wheels and tires now. I may adjust after. We will see how she sits.Looks amazing. What setting did you put your front coils to? Did you increase it more than it came from the factory?
