Shaking at high speed - is this normal?
satchamo
Indiana
2021 STX
so my 21 screw STX with a 5.0 has some pretty annoying vibration at and around 80 mph. My passenger seats shakes pretty badly and anything in that seat shakes a lot. Like a simple McDonald’s bag which makes a bunch of noise. I have done nothing to modify this truck - completely stick with 1600 miles on the clock.
so I had my truck into the dealer a week ago over this issue and they test drove it and identified it as “flat spot” on a tire so they replaced a tire and said it fixed it… we’ll it didn’t.
could some of you other owners watch this video and tell me if you can discern the vibration I’m referring to?If you crank up the volume you will hear the bags shaking. I only ever drive this speed on interstate before anyone asks why I need to drive 80….
is this normal or should I take it back in? I already left it with them for 5 days to not get a fix…
rado
United States
2024 XLT Powerboost
While I do not have my truck yet, I can be pretty sure that that's not normal. You can actually see the seat shaking in the video, suggesting its a pretty big vibration. Is it completely speed dependent or does it do it at all speeds? If I had to guess, I'd say that you probably have a tire or two out of balance. I'd take the truck to a shop that has a Hunter Road Force Elite Balancer (https://www.hunter.com/find-equipment/). I've found that they balance the tires much better than other equipment as they put an actual load on the tire during testing. Every time i've added larger M/T's to a truck I'd have to get them taken to a road force to get the vibrations out of the drive train.
Jerry Can
Calgary
2021 F150 KR Powerboost, 2-tone Rapid Red, 157”
Fuel Container
That vibration is definitely not normal. My truck is perfectly smooth at 80mph. Did the dealership check wheel balance and alignment?
BMWtoF150
Marty
SC
2021 F150 King Ranch, 3.5 Eco
Retired, Part Time Consultant
My 17 f150 had the same kind of vibration @ 75 +MPH. I had all the tire balanced at Discount tire and it corrected most of the problem Part of the problem was the Good Year tires that came on the truck. They just rode bad. Once I put Michelins on It was very smooth. My 21 has Parelli tires and has been very smooth for the 9700 miles I have driven it.
satchamo
Indiana
2021 STX
Let me take a pic of the service ticket and it will indicate what they did
Predator
Billy
British Columbia
2021 F150 2019 Escape
Had a vibration problem in my 2018 5.0 the rear axle gears were bad dealership changed them and vibration was gone
satchamo
Indiana
2021 STX
Ford F-150 Shaking at high speed - is this normal? 40B8642B-BD5B-44D1-93BE-AFBC2612AED2
So here is what they gave me on the tires
seems like way more road force on both front and rear on right side but I literally have no idea what this means haha
KartRacer25
Richard
San Diego
Should definitely be rock solid up to 106 mph all day long.
Saw a few post on drive line issue and other vibration sources. Something about angle of drive shaft or something. Plus some earlier recall issues. Do some searching on virations here and other F150 forum under 2021's
Hope you can sort it out.
mtbmj
Matt
2021 F150 SC / 2021 Ranger SC / 2018 E350 / 2018 E
sales
2021 F150 SC Lariat 502A pkg 3.5 EB having NVH most noticeable 50mph thru 60 but at lower mph and higher mph to a lesser extent. Selling dealer hooked up a sensor system and did a trans / torque converter test as recommended by Ford Corp. no resolution. I checked drive shaft visually and noted RPM vs gear selection to no avail. Any help here? 20" w Pirelli had winter setup, same issues. Stock suspension no mods on anything.
Jayet96
Jaye
2022 F150 XLT FX4 Supercrew
2022 F150 XLT FX4 with 2300 miles. I’m having same issues. Installed level kit and 275/70r18 Cooper Discoverer AT3 after I took delivery. I’ve had the tires balanced 2 times, road force balanced yesterday and still shakes. I have an appt with selling dealer on Friday. At this point I’m thinking it has to be an issue with the truck.
1ockdown
Doug
New York
'21 F150 XLT
R&D
Did anyone here have this resolved? I’m currently going through the same and had 5 dealer visits in 3 months.
Samson16
Orlando, FL.
Aviation systems
Smooth and powerful all the way to 106mph. 80 is no different than 40 which is no different than 100.
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hey, Doug. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to see how I can assist you with this shaking concern.
