Scratched door pillars w/ swirl marks
Chilidog
Todd
St. Louis, Missouri
2022 F150, Lariat, 5.0, Fx4, 502A, Carbonized Gray
Did anyone else's truck arrive with swirl mark type scratches on all of the door pillars? My rep apologized and said all new vehicles arrive like this and they are not sure why. I showed the rep the pillars on the VW I traded in and they are perfect. Not sure how much of a big deal to make of this, but it is really unacceptable for a new vehicle.
s.v.t.
Jake
Missouri
Building..
Tell your rep he is an idiot and you can tell him I said that.
I second this. I hope and presume the swirls/scratches can be easily buffed out?
Zengineer
Midwest
2022 Lariat 157wb
Not sure since they are plastic. I know black PPF can cover them.
If there is something (other than covering them) that will improve them, I haven't found it yet...and I've tried everything from Meguiar's PlastiX to Polishing Compound to Waxes to various Trim Restoration products. I am not sure how they are made but suspect the swirls may actually be under the top most coating layer.
I see the Interweb says to tape off around them and go after them with a correction compound and orbital so maybe I just haven't been aggressive enough. I'll try that route. If I ruin them I'll cover them.
Blue22
Southeast, PA
My previous vehicle’s b-pillars scratched easily when I first got it so the first thing I did when I got my truck was have ppf applied to them. The guy who put them on said minor scratches and swirls would be covered by the ppf so maybe it would be worth trying if it’s not too bad.
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
me to. my passenger side b pillars covers got scratched from me touching them with window shades
pkinneb
Paul
Zimmerman MN
You can get them out (polisher) but unless you are handwashing your car and using good microfiber towels good luck keeping them nice. Film is your best option if you're not doing as stated above.
  • Like
Reactions: 780
athenslb57
AL
22 F150
I'm handwashing with foam cannon and they still look like crap. They are scratched when they leave the plant.
pkinneb
Paul
Zimmerman MN
Totally agree. I was just suggesting if you do polish them back to no swirls and go through a car wash you will be back to swirls
PatchManager
Colorado Springs
Firmware Engineer
It is possible to machine polish the b-pillars, which I just did to our Toyota Highlander. It is a our family car, so there were many scratches. The process is not difficult, but not trivial either. In my case, machine polishing was necessary since polishing by hand did little. I was fairly concerned about making them worse with polishing, but they turned out nicely. Start with polishing compound first and then move to cutting compound if the polishing compound isn't enough. Gradually move up to higher RPMs on the buffer.
