Request VIN Lookup Thread
Doyleap
Aaron
Doylestown, PA
2023 F-150 PB
Can someone please check mine for any updates?
1FTFW1ED2PFA11616
It looked like an OTA update for bluecruise failed, then I lost audio volume (stuck at 0) and now the truck is dead in the driveway
rugedraw
Javier
Miami
Auto Sales
1FTFW1ED2PFA11616
The OTA failed citing the error message:
"errorCode":"\"utcTime\":1760043984"
If what I am seeing in PTS is correct, the update neevr tried to install. Battery was way too low at 43%. However, the truck has been steadily reporting some codes of concern. The PCM code in specific. Seems like your truck has a cataluytic coverter issue. It does not seem like the OTA is at fault here. If the OTA bricked the truck, you would have a very specific message on your screen. I don't think the two issues are related.
Ford F-150 Request VIN Lookup Thread 1760540820361-uy
ti
jeffrt
Belle River, Ontario
2021 F150 Lariat, 5.0L
Hi, could I please have my VIN checked?
1FTFW1E53MKE02298
I’ve had the 6.7.0 update fail several times now and am wondering if it’s a battery issue, especially seeing that someone else had it go through after swapping their battery.
Thanks!
ken325i
Ken
PA
2021 F150 King Ranch
Hello
Could I please have my VIN checked? 1FTFW1E89MFA78177
My last update OTA update was a year ago.
Many Thanks!
Ken
rugedraw
Javier
Miami
Auto Sales
Thanks!
The battery is the reason it failed both seems. SoC was very low at 23%, and it timed out and failed after trying several times. You may just need to charge the battery up next time they send it to you; it doesn't necessarily need to be replaced.
Ford F-150 Request VIN Lookup Thread 1760646931227-y0
Hello
Many Thanks!
Ken
I can no longer check for pending updates. I see they have not sent you one in a while, but connectivity is working fine and I see no reason whjy you would not be able to get updates should they send one to you.
jeffrt
Thanks for checking. I tried hooking up my charger after a couple failed attempts, but it may have been too late. Guess I’ll just wait it out.
rugedraw
Javier
Miami
Auto Sales
Is your battery the one is was built with? If so, then it may be time to get a new one and go with at least an H7.
jeffrt
I got a new battery from the dealer at a year old, replaced with another H6. That “new” one is almost 3 years old now. Crazy that that’s considered getting old for these trucks. I shut off my auto start stop a few months ago, and it seems to be holding better voltage, but it could still be weakened I guess.
rugedraw
Javier
Miami
Auto Sales
It was at 79% earlier this morning the last time your truck reported itself to the mothership.
MrT
Matt
Az
2021 F-150 Lariat PB 502A
FWIW my original 4 yr old, H7 tested at dealer with 80% and 770 CCA. But deep sleep activated every night "to preserve battery life". Even after driving. So....I took the $300 plunge and got a new H7, didn't want to risk a dead truck btwn Amarillo and Albuquerque on an upcoming road trip. The updates started rolling in OTA, downloaded, installed and updated all the way to Sync version 25094, rev 1779. Ford holds updates hostage until state of charge is optimal.
PatchManager
Colorado Springs
Firmware Engineer
Could someone please check for any updates for 1FTFW1ED7NFC16877? It is currently at the dealership, so I would like to see if anything is pending.
