Request VIN Lookup Thread
Seahawk51
Curt
2017 Mercedes GLS450, 2013 Chevy Equinox, 2021 Ford F-150 on order
That's a pretty old version at this point. However, looking at what the dealer did on 5/14 when your new APIM was put in, they seem to have programmed it correctly. Your connectivity is working fine and you do show an APIM update pending. Your truck is not reporting any codes of concern and everything seems fine. Looks like just crappy luck with the OTA process to me.
Thank you very much. Oh, and for the record, my truck is about 30 feet from one of the nodes of my ASUS Mesh Network. Connectivity cannot be an issue.
rugedraw
Javier
Miami
Auto Sales
I too would appreciate an fdrs update check. Been a while since I’ve had any updates
1FTFW1E56MKD95895
Thanks
kevin.
Glady, but please remove your VIN from the request. Truck is on Sync 23291 which is only one version behind the latest. Modules with pending updates are below.
Ford F-150 Request VIN Lookup Thread 1740164468697-b0
99% of updates are download via the vehicle's modem and not wifi, so that doesn't really matter. Even if you unplug the modem, if your VIN comes up for an OTA, the server will still try to send it......it just won't go through. Whether a vehicle is connected to the cloud or not makes no difference in terms of when an OTA will get sent.
Los150
Carlos
2023 3.5L EB Platinum w/BAP
Info Tech
Where in FL are you? If you're close enough, I could let you use my mongoose cable if you don't have one.
Seahawk51
Curt
I'm in St Augustine. And while I'm very computer literate, I must admit too having a fear of bricking my truck!
Los150
Carlos
Info Tech
Damn. South FL.
The first time seems a little intimidating but if you stick to the process outlined by everyone here and don't go doing things you shouldn't, then everything should go smoothly.
TMicallef
Terry
Trenton, MI
2022 F150 XLT
Automotive Supervisor
According to my Ford App my last OTA software update was done on 1/5/25. Why does my Sync screen default to the "settings" screen on startup? Is this a glitch with the OTA updates? I have it scheduled to auto update as needed but it's getting pretty annoying that this is happening.
Ford F-150 Request VIN Lookup Thread 20250224_102412
Ford F-150 Request VIN Lookup Thread 20250224_102338
lordofping
US
22 F-150 Plat Powerboost
Good afternoon all - I'd like to request a lookup for available FDRS updates for this VIN:
I would appreciate being able to check if getting a 2 day FDRS license is worth the effort
rugedraw
Javier
Miami
Auto Sales
Gladly, but please remove the VIN post.
Your truck is a 2025 with a build date of December. Not updates showing yet. Save the $50.
lordofping
US
Oh fascinating, I didn't realize it was that new
It is having hard shifting problems, and I was hoping the solution was as simple as an update
Guess not :'(
infotech30
James
Vicksburg, MS
2021 F-150 XLT Crew Cab
Good afternoon,
I am wondering if you can check to see if it have any pending updates? I would like to know if it's worth spending $50 on a license.
Thanks,
James
Vin:
rugedraw
Javier
Miami
Auto Sales
Good afternoon,
Thanks,
James
Vin:
Only showing the BCM which you can't do and the two door modules. Save the $50.
TMicallef
Terry
Trenton, MI
2022 F150 XLT
Hello all,
Could you see if I have any pending updates?
rugedraw
Javier
Miami
Auto Sales
Hello all,
Could you see if I have any pending updates? VIN
Gladly, but please remove your VIN from the request.
Ford F-150 Request VIN Lookup Thread 1740525695707-b4
TMicallef
Terry
Trenton, MI
2022 F150 XLT
