Grafx36510
Thanks! Looks like I have an update ready to go, but I guess I’ve reached phantom update level. Go me!No, nothing yet.
With the current issue, having a Mongoose/FDRS would make no difference. The files are not on the server, so they won't come in OTA or via FDRS. This issue started a few days ago, so it would not explain why you haven't been sent any updates. Right now, you would not be able to do the updates either way.Working in the tech industry myself, Ford really seems to be beating around the bush which would line up with what you said indicating a larger issue. I'll pull the trigger on FDRS & Mongoose if it comes down to it but that pretty well confirms my suspicion..
Thanks again!!
This is a bit more complex to check. Remind me tomorrow to look into it.Can I get a VIN Check? I have not received an update since I had it in the dealer for a gateway issue. 1FTFW1E8XPFC33047
Yeah not having any updates ever is what has me puzzled, I've read your threads and understand how the process works with the updates having to be available. Going back to the issue that started a few days ago, did they recognize files became unavailable on the server or maybe in my case have never been there at all ?With the current issue, having a Mongoose/FDRS would make no difference. The files are not on the server, so they won't come in OTA or via FDRS. This issue started a few days ago, so it would not explain why you haven't been sent any updates. Right now, you would not be able to do the updates either way.
Tbh, I don't know if Ford knows there's a problem yet. We usually find out before they do. ?Yeah not having any updates ever is what has me puzzled, I've read your threads and understand how the process works with the updates having to be available. Going back to the issue that started a few days ago, did they recognize files became unavailable on the server or maybe in my case have never been there at all ?
Whatever appeases the OTA gods, I guess. lolParked my truck on the street again since I was cutting cedar with my Miter Saw for a playset. Got another one. I realize this is probably a conciidence.
Can I get a VIN Check? I have not received an update since I had it in the dealer for a gateway issue. 1FTFW1E8XPFC33047In an attempt to keep the other threads clean lets use this thread to request VIN lookups from anyone with an active FDRS or PTS subscription.
Please specify if you are looking for OTA updates (done via PTS) or module updates (done via FDRS)
Please do not PM asking for a VIN lookup, please use this thread
Here's some good OTA information courtesy of @JScaro
https://www.motorcraftservice.com/Home/SetCountry?returnUrl=/Purchase/ViewProduct
I see no indication in your warranty history that any work was done to the GWM on your truck. Can you elaborate a bit so I know what to look for? PTS is down now and I cannot check OTA dashboards, but I checked yesterday when you posted and saw you have no OTA history.Can I get a VIN Check? I have not received an update since I had it in the dealer for a gateway issue. 1FTFW1E8XPFC33047
PTS is partially down. I cannot pull of OTA dasboards.@rugedraw
Good morning Javier.
When you got a moment, could have a look and see if the BCM update that was showing in PTS is still there? I got CSM2 on the 14th, a BCM update, and it looks like my double tap for tailgate was changed to single tap. I check my quad lights and they are good. I checked my truck with Forscan this morning and there are no codes showing.
Because I am off the bumper to bumper warranty as of May 6th, I was thinking about updating what ever is showing in FDRS around the middle of April. If something is screwed up, the truck is still under warranty.
Thanks
1FTFX1E81MKE01710
I understand - when it is back up and you have time.PTS is partially down. I cannot pull of OTA dasboards.
I was "told" they updated the Gateway module. while they performed updates to a APIN Moudules. I can PM you the paperwork they gave me. ) Beyond frustrated in this.I see no indication in your warranty history that any work was done to the GWM on your truck. Can you elaborate a bit so I know what to look for? PTS is down now and I cannot check OTA dashboards, but I checked yesterday when you posted and saw you have no OTA history.
I just need the date range of when they truck was there so I can look at vehicle history and see if they did anything or not.I was "told" they updated the Gateway module. while they performed updates to a APIN Moudules. I can PM you the paperwork they gave me. ) Beyond frustrated in this.![]()
[/QUOTE
It was there on3/14 -3/15I just need the date range of when they truck was there so I can look at vehicle history and see if they did anything or not.
