Red Rocket is almost complete!
Jmitchelltfo
Jeremy
Ozarks
2021 King Ranch PB
Range Ops
True...but with the 10R80, the last two numbers are it's torque rating in Newton Meters.
80 = 800nm.....which equals 590ftlb of torque.
10R80 in the Aviator hybrid has to hold 630 lb ft…..so I’d say it is probably rated for at least that.
Porpoise Hork
Bret
IT Sys Admin
I may be wrong but, it would be sheer insanity for Ford to install a transmission that the maximum torque rating is only a measly 20 lbs-ft higher than the total rated for the truck. Just running a tank of super unleaded would potentially put the combined total output at about 590 lbs-ft in certain running conditions. If it's maximum torque handling capability were that close It'd be like Icarus and we'd certainly see a lot more powerboost's with burned up transmissions as a result.
amschind
Adam
'21 F150 SCrew 4x4 Powerboost
Physician
I think the crazy next step would be a twin turbo Coyote on a 10R8MHT.
Tank
Tank
Jay
New Iberia Louisiana
2021 XLT Powerboost 2wd
Tank
Tank
Jay
Well. I didn't make it up.... that's how the Ford transmission is rated.
The 10R110 is 1100nm, which is 811 ftlb of torque.
....and the Powerboost is around 490ftlb at the wheels, which is far under what the transmission is rated for.
Tank
Tank
Jay
Most likely that 630lb ft is at the crank, so it's probably like 540lbft at the wheels, so it's still within stock rating.
Porpoise Hork
Bret
IT Sys Admin
And it's not producing that level of hp/torque 100% of the time. Only when you floor it and even then it likely would only be for a few seconds.
