Kubko
Hello, I've found FORScan spreadshet for 2021+ F150 by Livnitup. The IPC section came to me really handy as all of the addreses have description and they work on 2018+ digital cluster I'm going to retrofit to my 2017 Mustang (swap from analogue IPC).
I was able to prepare myself programming for whole IPC section, I had to disable various features my car doesn't support, did AsBuilt comparisons with different 2018+ cars that come with digital dash from the factory, etc...
However, I left myself a note on some addreses and I would like to ask on what's unclear. Maybe someone experienced can give me some information on those, and what is their purpose:
IPC
720-10-01: *xxx xxxx xx--
This changes Transmission Temperature Curve (TTC), the 2018+ mustangs seem to use TTC Table A: 10R80, 8F24, 8F57, 9F35, 9F40, 8F35 what makes sense, since 2018+ got 10R80 tranmission, however my 2017 should use TTC Table C: 6R80, 6R140, 6R100, HF35, HF45 since I have 6R80 only. However I'm also able to use third option which is TTC Not Used. So now I'm not sure what does this affect. I have an option to disable it completely or use TTC Table C.. But even if I use table C I'm not sure if my car has such feature till I won't know what does Transmission Temperature Curve affect...
720-04-01: xx** xxxx xx--
This changes FuelG_InitStep (FGIS), the digital cluster should use FGIS Init_Step 2, but when I compared it to my asbuilt (analogue IPC) I have FGIS Init_Step 0 set. By the name I assume it's something about Fuel Gauge?
720-04-01: *xxx xxxx xx--
What is difference between IFEN Graphical and IFEN Numeric value? Have no clue but US Mustangs use graphical and EU (export) Mustangs use numeric..
720-09-01: xxxx xx*x xx--
This changes Infotainment Control Mirror (ICM), it should be enabled but I cannot compare it with my AsBuilt since my analogue ipc doesn't even have that address. What could it do?
Thanks.
IPC
Thanks.
