question about our 4WD system..
FORDTEXAS
2022 F150 LARIAT
I know for a fact that our rear axles can be equipped with a locking differential. the front however doesn’t have anything unless one jumps up into a TREMOR/RAPTOR.
with that being said, are our fronts just straight up open differentials or is there some sort of technology that replicates a locking/limited slip differential e.g. Tacomas/4Runners with ABS braking that simulate a locking/limited slip differential.
Tnker
Pa
23 f-150
Its an open diff with some brake torque vectoring when slip is detected. They even stopped putting the Torsen in the front of the Raptors in 23.
That being said I haven't been in a situation where I felt like I needed anything more up front in my 23 Raptor.
The ABS is more than capable of doing it, and ford has the engineers to make it near perfect. The team that did the vehicle dynamics on the mach-e has that system dialed in quite well. It's got 2 separate motors, 1 front, 1 rear, with completely open diffs. When a wheel comes off of the ground, the wheel in the air maintains speed effortlessly. I've seen no official literature mentioning such functionality, and there seems to be more questions than answers. I couldn't imagine having the amount of engineering into modern vehicles and not have one of the lead engineers from each department clearly spell out the functionality of the various systems.
Anyone in colorado that can take the truck over to TFL and borrow their rollers and try a 3 wheel slip test in each driving mode? This post is worth a read https://www.f150gen14.com/forum/thr...y-controls-esc-traction-control-tc-help.7747/
JExpedition07
James
Buffalo NY
2023 F-150 STX 5.0L V8
They do use braking bias but it sucks. The Torsen also isn’t quite as good as a selectable locker, there are some good videos that show the Torsen weakness. Its weakness is in low speed crawling or bogging, it doesn’t lock up without pretty hefty throttle application where a selectable locker would just be there whenever you want it. I’d call the Torsen a 50% improvement over the open diff, but it’s not quite the 100% solution a locker is like the locker we can option on the rear axle.
FORDTEXAS
FORDTEXAS
2022 F150 LARIAT
damn so is the torsen even optional at all then?
Scoobtay
Taylor
Oregon
2023 PB XLT
I’ve had front lockers in the past on different trucks, and I couldn’t imagine realistically needing it on a F-150. How many of us are three wheeling these and taking them up 40 degree black diamond trails?
Can't believe they deleted it in raptor. Still in the tremor.
145" wheelbase is a bit too much for such things. Still has its uses though in off-road other than rock crawling.
Chris GTO TT
Lincoln CA
2023 F-150 XLT 302a
The weird part is given the stated design mission of the Tremor and the Raptor and how a Torsen diff works it makes more sense for it to be in the Raptor than the Tremor.
FORDTEXAS
FORDTEXAS
2022 F150 LARIAT
do our trucks have to be in any particular drive modes or simply disable the traction control??
Ziggy73
Keven
2021F150 Powerboost
Radiologic Technologist
I saw a guy on TFL special order a short bed single cab four-wheel drive regular F-150, no special packages and he somehow got them to add the torsen front end to his. I'm sure you can search it up on YouTube under TFL. I can't remember the title, that would make it much easier. But I wasn't aware that they weren't as good as I thought they were after reading one of the other members posting about it it's weaknesses. It might just be easier to get an aftermarket e-locker in the front.
Chris GTO TT
Lincoln CA
2023 F-150 XLT 302a
It's a Ford Performance dealer installed option. So you can get it installed on just about any F150 4x4.
FORDTEXAS
FORDTEXAS
2022 F150 LARIAT
i’m still confused fellas.. does the “brake torque vectoring” engage automatically in a wheel slip situation or does the driver have to initiate a button/setting??
FORDTEXAS
FORDTEXAS
2022 F150 LARIAT
shoot.. ABS on the Tacomas/4Runners is amazing. i’ve seen a handful of videos of those 2 rigs laying down the pipe while in a hairy situation.
Oh yeah, they've got that sand crawl thing too which is badass.
