Pro Trailer setting up via just measurements?
natefons
Philly
F150 Platinum
On my older gen for setting up trailer on pro trailer, all I had to do was do some measurements and then do a very light driving to calibrate.
on the gen 14, the measurement part seems to be taken out, and now calibration seems to be somewhat automated via driving.
problem is the driving it needs is nearly impossible where I live.
I wants me to drive left and right, but even after a nearly 90 degree turn, it still wants me to continue to turn. I don't really have that much open space where I Can just take the trailer and just drive around.
The measurement approach was great...is there away to do that on gen14?
Davexxxx
MO
I haven't done mine yet but when the time comes, a store parking lot or school after hours, seems like a likely place.
Meterman
Medina OH
2024 F-150 Lariat PowerBoost 7.2Kw
Yep, I went to a grocery store parking lot to do mine.
EricR
Eric
Boise, ID
Does your new truck have BLIS?
Are you using the yaw sensor or the stickers?
What year is your truck?
FTMS
New Hampshire
2005 Titan
You really just need a parking lot. It just wants you to drive in a circle. I can not say for sure since my truck did not take to there procedure.
Aron
Aron
Civil Engineer
I agree with other posters above--I would find a suitably large parking lot (at a grocery store or shopping mall, for example) so that you have space to make the requested turns. Also, for what it's worth, if you run out of space before it completes the requested turn, just drive where you can--it'll take longer to calibrate, but should still work. When you finally do turn appropriately, the calibration should pick up where it left off.
When I went through my calibrations, the grocery store parking area I used wasn't quite large enough, so I had to do a bunch of loops to get it all squared away. Just keep the speeds low so it doesn't cancel the calibration mid-stream.
dhrandy
Randy
Concord, NC
Engineering Tech
There's usually enough room in a school parking lot on a Saturday or Sunday. If you're using the yaw, be sure it's plugged in all the way.
GEN14OWNER
Bob
North America
2021 RCSB 5.0 F150 XLT
Yes BLIS
stickers
2021
I don't know if the Module is different from the Stickers but my 2021 XLT came with the Module and the driving I had to do was pretty minimal compared to what the instructions indicated. Walmart parking lot did the trick with plenty of room to spare.
redline
Calgary
2025 f150, BMW M3,VW Atlas
I just did mine , it. Would be helpful to do it in a large empty parking lot, I did mine on a quite back road , but the turns where a problem in the set up. you only do 5 miles or 8 kms couple of straight stretches and couple of turns …
