Pro trailer back up assist
Boen
andy
washington st
22 F-150 Platinum
When I push the button for pro trailer back up assist ,screen pops up and ask if the trailer is hooked up or not, and when I choose, yes it comes up with the list of my trailers and every time I select one nothing registers or goes any further, I even tried adding a trailer which it let me, but it doesn’t go any further
Tone
NY
'21 XLT Sport, 3.5 EB
Did you perform the alignment procedure. Is the target sticker installed on the trailer?
Boen
Boen
andy
washington st
22 F-150 Platinum
Can’t get any further than that screen that I posted
Ford F-150 Pro trailer back up assist IMG_8132
Boen
Boen
andy
washington st
22 F-150 Platinum
Yes, I tried pugging it in many times. The dash shows trailer hooked up
JIMFOUNTAIN
Jim
Austin, Tx
2021 F150 SCREW PB 6.5' 701A
I have the same problem... an OTA messed up something in my configuration. Still haven't figured out exactly what.
Do you have the trailer brake controller? Does squeezing it or pushing the gain buttons do anything?
scott
California
2024 F150XLT
Ok. If I’m not mistaken you need to calibrate the trailer. And, to do so be sure the calibration sticker is in place then go to a large parking lot and try it then. I found it won’t go further if it’s just in the driveway.
I hope this helps
Also, I had to put in the hitch, sticker dimensions before I drove the parking lot to calibrate. I just had the dealer update my Sync4 to the latest revision a couple of weeks ago (24127)
so, it deleted my save trailer info. I appears that now instead of re-entering those dimensions it tells me to drive it to calibrate. That I haven’t done yet
2024F150XLT
Boen
Boen
andy
washington st
22 F-150 Platinum
I do have the Brake controller. I will go try that.
Boen
Boen
andy
washington st
22 F-150 Platinum
I hope this helps
2024F150XLT
Can’t do anything won’t go past that screen that I posted
JIMFOUNTAIN
Jim
Austin, Tx
Boen
Boen
andy
washington st
22 F-150 Platinum
When I hit the trailer back up button the screen pops up and ask if trailer is hooked up , If I say no it will do the Pro trailler hook up assist but if I hit yes the screen shows list of trailers but I hit any of them it dosnt go anywhere, The screen acts like it responds to the comand but dosnt go anywhere?
SilverPigeon
Australia
I worked through it in private messages with @Boen Andy. The solution was:
Change TSF & TSC:
APIM: 7D0-01-03 xxxx xx*x xx-- change 3 to F and
1. Reboot APIM;
2. Clear and rescan DTCs.
SilverPigeon
Australia
