matsperzak
- First Name
- Matt
- Joined
- Apr 27, 2021
- Threads
- 1
- Messages
- 10
- Reaction score
- 3
- Location
- Denver, CO
- Vehicles
- 21 Ford F-150 PowerBoost, 08 Porsche 911 Turbo
I heard my little plastic piece drop and roll on floor as I removed the pump yesterday. Could you elaborate on how you fit it back in. Doesn't look like mine is broken, just dislodged. I was able to get it to click back into the truck and when I pressed the button it shot out (rather intensely). Are you supposed to re-connect it to the fuel door? If so any tips?My fuel filler door had the same issue today. Filled the tank, closed the door, drove home and then the error message came on saying the door was open. I pushed in on it and the message was still on so I opened it manually, and the Little plastic piece that sits inside the rubber shroud shot out at me like it was spring loaded. Landed on the ground. I scheduled an appointment to have the dealer fix it, but then when I messed around with it tonight I was able to get it locked back in. I think it is just barely seated inside the fuel door, so you will have to be really careful when you remove the gas pump handle because if you bump it at all, you will dislodge it. I am going to have to try to figure out how to have some extras of those in the cab so that if I ever lose it, I have an extra one I can use.
