Powerboost CEL P237C/Exhaust Heat Exchanger Leak Megathread
Gros Ventre
Western Wyoming
Another possible leak path is from the coolant side to the exhaust side. You'd expect the exhaust side to be at a higher pressure than the coolant, but gas flow can be a funny thing since a low pressure area or eddy can form allowing the coolant to be drawn out of the cooling circuit. If this is the case, then the lost coolant is being evaporated and sent out the exhaust pipe... Thus you'll never see the telltale evidence of the coolant. I doubt you'll ever see any evidence of coolant in the exhaust piping, although you might check. If Ford hasn't done a tear-down of one of these heat exchangers to look for such things, they need to be doing them on returned heat exchangers.
ThyDayWalker
Bridge City, TX
2021 F150 PB Lariat 502A
Another way to come close to this is Park the truck for a week (or more if you can stand it!) and see if any level change occurs with it having been thoroughly cold the whole week. Then take a week and either drive it every day to full warmup, or if you don't drive every day warm it up completely and then idle for maybe 15 minutes after fully warmed up. Then at the end of the week see if level changes. Maybe not as good as the UV light test they can do but is an indicator.
The good thing is that it has sat for weeks at a time, with a definite change in level. Not concerning, but say 1/4 to 1/3 of the way between MAX and MIN. As of last week I set up a spot on the hood to prop my phone and take a picture, and plan to do it every week - that way I can properly document the level drop.
Once I get enough data of it sitting still, I'll try to then see what happens if I use it more vs. level drop... Good points tho! I hadn't thought about heat cycles / etc ...
PeaksFord
2022 F150 3.5L Powerboost
NameBlendBed/ PartTold DlrMilesCan Drivepart orderedpart arrivedInstall DateIssues After?
Dan65 repair#112/22/215.5/W1/20166No01/20/223/17/2022 56 daysYES - ~5000 miles, in May leaking again
Rhymeand reasons01/05/225.5/W2/161990No02/18/223/9 - arrived damaged - re-ordered 3/9 - arrived 4/74/8/2022 51 daysNo!!!
Nasto01/05/226.5/V2/22296NoWrong -S part ordered: 2/23/22. Re-ordered -V: 03/09/22.3/29/20223/30/2022 37 daysno
Cuse0307 repair#101/15/226.5/V3/193300No03/20/225/13/20225/13/2022 55 daysYES - 900 miles and leaking again
Bellin stoke02/01/225.5/W3/232600No----4/14/2022 22 daysno
Thunder chief12/23/215.5/W3/281237No03/28/224/25/20224/26/2022 29 daysno
MTPower boost12/06/215.5/W4/83127No04/06/225/11/2022 33 daysNo - 150 miles so far
Matthyius01/06/226.5/V4/183930No04/22/22scavenged off new truck in lot6/20/2022 63 daysNo - 460 km so far FORD offerign 3 month payments 8yr/180k km warranty
Deeds972MY226.5/V5/94800No5/23/2022 14 daysNo
Oxford_Po werboost09/27/215.5/W2/77600Yes02/07/225/20/20225/25/2022 107 daysno
Dmark john12/20/215.5 W2/21400Yes02/21/223/10/20223/11/2022 18 daysNo- have 4K miles post repair and everything is good
iceman7701/06/225.5/W2/221707Yes02/24/224/21/20224/23/2022 60 daysno - ~5k miles so far with no leaks
MrFarly repair#101/04/226.5/V4/88000Yes04/11/225/11/20225/12/2022 34 daysYES - @ 2500 miles leaking again
MrFarly repair#201/04/226.5/V6/610900YesCorporate Ford tech expedited and looked at this 2nd leak6/14/20226/21/2022 15 days
TN Rotty12/19/216.5/V3/11100Yes03/07/22
DB6312/14/215.5/W3/141000Yes03/14/22
Ford Driver01/22/225.5/W3/29300No04/22/22
RyanC1114/21?6.5/V4/77694Yes05/25/22
Klvanzu01/16/225.5/W5/113100Yes05/11/22
Sir Choppins12/17/215.5/W6/21200Maybe06/06/22
Cuse0307 repair#201/15/226.5/V6/64200Yes06/06/22New V part leaking after 900 miles
Dan65 repair#212/22/215.5/W6/95002No06/09/22Estimated 7/18
emiantan12/20/225.5/W6/166728No06/17/22
Puddle01/09/225.5/W6/202000 kmNo6/23/22?
70mach112/16/215.5/W6/224500No??
PeaksFord??5.5/W6/284852No6/7/22
Original part# (dependent on bed size) ML3Z-5A212-S.
The updated part for a 5.5 foot bed is ML3Z-5A212-W.
The updated part for a 6.5 foot bed is ML3Z-5A212-V.
For any new records get me the info in a column like so :
Name
Blend (build date of your truck)
bed length/
part letter
told dealer date
mileage when leak noticed
drivable y/n
part ordered date
part arrived date
installed date
any issues after
Example:
TN Rotty
12/19/22
6.5/V
03/01/22
1100
Yes
3/7/2022
If you have no info for a field, no worries - just put ??? or similar for that item
TN Rotty
Mid - TN
2022 F150 Crew Cab Plat 6.5'
@PeaksFord - welcome and condolences for being on our list.
You told the dealer on 6/7 and they ordered the part on 6/28? (dates are reversed on the form - which I can add to the sheet later)
PeaksFord
Ah yes, I am sorry, no coffee yet. 6/28 and 7/7 as far as I know.
To compound it I also have a electrical failure preventing vehicle start. No idea if thats the same everyone else's whos doesnt run though.
My dealer is trying to pursue a VLA deal to buy it back.
Gros Ventre
Western Wyoming
If someone says such heat driven leaks are rare... they're correct. But they do happen and if they do they kick your butt trying to find them............
TN Rotty
Mid - TN
Ouch - sorry to hear. Hope it comes to a successful resolution for you.
Sir Choppins
Patrick
Bartlett, TN
2022 F-150 Lariat Powerboost
Operations Manager
Name
bed length/
part letter
told dealer date
drivable y/n
part ordered date
part arrived date
installed date
any issues after
Example:
TN Rotty
12/19/22
6.5/V
03/01/22
1100
Yes
3/7/2022
The Heat Exchanger for my truck arrived yesterday and they installed it this morning.
Part ML3Z 5A212 W
Now I pray that this replacement part does the job!
TN Rotty
Mid - TN
Part ML3Z 5A212 W
Good to hear - Did they have your truck the whole time, or were you driving it while waiting for the part to arrive?
PeaksFord
Found out today that the AC/DC Invertor was the cause of the failure to start on my truck, secondary to the coolant leak issue.
Ironically, these are on national back order also.
I'm now told to go and find a new truck I like, and they will make it happen..... however, there are no fully loaded Platinum's out there that had all the options I had previously.
WBL_Chzhd
Al
2024 F150 Powerboost XLT Avalanche BAP+
How are you all getting compensation (payments/extended warranty) from Ford? My Powerboost has been in since June 11. I called customer "care" on Monday. They told me I could rent a truck on my own and get reimbursed when my truck was fixed. No other offer. Dealer had nothing for me to drive. I'm driving my kid's Jeep right now, so I'm not going to rent a vehicle and front the money for potentially months.
emiantan
Utah
2022 Ford F-150 Platinum PowerBoost
My dealership setup a rental through Enterprise with Ford footing the bill until the part is replaced. They were able to get me into a heavily-used 2020 Ford F-150. I believe it is a $60/day rental and I am approaching 30 days as well which $1,800/month is a steep price to buy for this delay. I have not reached out to my dealership regarding any further compensation such as reimbursement for truck payment until I reach the 30 day mark. I understand there are some who have stated they have received said reimbursement.
Sir Choppins
Patrick
Bartlett, TN
Operations Manager
Fortunately, I was able to keep driving my truck. They provided me with coolant to fill as needed over the last month.
thudnblunder
Bay Area, CA
2022 F150 PowerBoost
Cloud Software Architect
I'm sure many other folks have similar stories, but my current car is a 2009 Mazda6 with the Ford-Mazda 3.7L V6 in it with 190K miles. In 14 years of owning that car, I've had to top off the coolant ONCE, and that was after a summer drive through Joshua Tree National Park.
I've driven it from DC to FL, to NY, to Chicago, in WV, on the west coast up and down CA, Tahoe, Nevada... in winters and summers and I've only had to top up coolant once to bring it up from min to between min/max.
All these new features add a ton of complexity and reliability problems.
TN Rotty
Mid - TN
I might need to trade out for your old cooling system, mine decided the trip home was a bit much yesterday.
2x6 board for comparison...
Ford F-150 Powerboost CEL P237C/Exhaust Heat Exchanger Leak Megathread 20220715_043838
Picking up another gallon of coolant this morning. 136 days in on one gallon concentrate (2 dilluted gallons). This puddle and more frequent fills may signal a change in drivability. I hope they are shipping those parts this week.
