Power tailgate not going down with key fob
EazyD33
Dave
Pennsylvania
2021 ford f150 powerboost
Been having a problem on my 2021 powerboost where the tailgate won't go down with the key fob on the first try. The exact problem is this:
A: push button on key fob twice (no go)
B: push button once on tailgate (no go)
C: push button second time on tailgate, everything then works normal.
After going through the above steps, the tailgate will then go up and down with the key fob.
Is think it might be the motor. Is there any way to reset this (my thinking is like reseting the auto up/down on the power windows)?
svtzx2
New Westminster, BC
2024 F150 Lariat, 2024 Mach E GT
Food Inspector
I see for my 2024, they have an update available in FDRS for the RTGM (Rear Tailgate Module) Maybe this is available for you too and can fix this.
Fox146
Dana
21 limited sold
My 21 has done this as well although I haven’t noticed it lately but I’ve also done a bunch of updates . When I’m home next week I’ll have to give a try
Sojourner
Maryland
2023 F-150 Tremor
Retired Army / Disabled Vet
Mat not apply to your exact situation, but I have a similar issue where I was led to believe what's going on is a safety/security issue (i.e., you have to press whatever button several times to confirm it wasn't a "butt dial" and/or that the area is clear).
bug_hunter
Wisconsin
2021 F150 Lariat Hybrid
I had thought that a double press on the OFB should do the trick, but that isn't the case for me and my 2021 Powerboost. No luck with the FOB, but the button on the gate does the trick. Sure would like the FOB to work. Would prefer not to have to see the dealer on this.
