Stxf150
- First Name
- Jerry
- Joined
- May 13, 2023
- Threads
- 1
- Messages
- 2
- Reaction score
- 3
- Location
- Pasadena md
- Vehicles
- 2023 5.0 f150
- Occupation
- Public safety
I recently installed 2022 xlt power seats in my 2023 STX (manual seats). The xlt seats had blown airbags and I wanted my original cushions/interior so I removed my cushions, seat covers and air bag and installed to new power seat frame, I also removed seat belt latches and installed on new frame. I started with the passenger side. My passenger power harness under seat was easy to locate power/ground. It was the two thickest wires in the middle row(power violet/black stripe and ground was blk/blue same middle row . I used micro fuse tap and got power from fuse 27 on kick panel(constant power). I ran a ground wire from solid ground next to fuse box. I did not disconnect battery when installing , this caused airbag light to come on. It was easy fix with forscan , just cleared DTC and all good .
When installing driver seat I disconnected the battery before removing seat . My new power driver seat does not have memory so all you need is power/ground, so I thought . I had already added heated seats and had power/ground right next to seat harness. I tapped into my heated seat power/ground installed power seat and reconnected battery . When I started the truck no airbag light but my brake light was on . I then went to turn truck off and truck would not turn off even with key out of ignition. I pulled the fuel pump fuse under hood and engine finally turned off. I then unplugged the power/ground connections I added under driver seat , started truck and then truck shut off with key . I then hit power seat switch and still had power to seat . So if you ever add power seats to your 2023 Stx that has non power seats , all you have to do is plug driver seat in and you should be good to go .
Me adding power to the driver seat double fed the circuit and that’s what caused ever light on dash to come on and truck not to shut off with key removed . First time ever installing power seats maybe save someone from these issues.
