Hans Moleman
My truck did something weird today. When I exited the parking lot making a right turn the throttle was unresponsive for like 3 seconds then it suddenly kicked in. I scaned with Forscan and it seems like the DTCs are unrelated to the unresponsive throttle.
However I also got some weird DTC for the power steering which is totally unexpected.
I had the OTA GWM update 24-PU0227-VI-RBS earlier this week? Could this all be related to it?
Code: 00444 - Invalid Data Received From Body Control Module C
Additional Fault Symptom (82)
- Alive/Sequence Counter Incorrect/Not Updated
Status (-08):
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Trailer Module
Code: U0146 - Lost Communication With Serial Data Gateway 'A'
Additional Fault Symptom (09):
- Component Failures
Status (-08):
Module: Telematic Control Unit Module
Code: U023A - Lost Communication With Image Processing Module A
Status (-28):
Module: Power Steering Control Module
Freeze Frame #1:
- STEER_ROT_SPD: 0 1/min - Steering Pinion Rotation Speed
- STEER_PIN_ANG: 117.80 ° - Steering Pinion Angle
- SSHET_TQ_S2: 0.8 Nm - Steering Shaft Torque Sensor #2
- SW ALIGN_OFSET: 3.40 ° - Steering Wheel Angle Alignment Offset
- ECU_POWER_SUPPLY: 14.5 V - ECU Power Supply Voltage
- ECU_INTERNAL_TEMPERATURE: 19 °C - ECU Internal Temperature
- MOTOR_CURRENT: 1.00 A - Motor Current
- EVENT_TIME: 29099703 s (Thu May 02 18:52:43 2024) - Event time
- TOTAL_DISTANCE: 4289 km - Total Distance
- OUTDOOR_TEMPERATURE: 15 °C - Outside temperature
- VEHICLE_SPEED: 32 km/h - Vehicle Speed
- IGN_CYCL_CNTR: 48 - DID EE03 Ignition Cycle Counter
- IGN_ON TIME: 36000.00 ms - Ignition On Time
- FINAL_MIR_TOR: 0.0 Nm - Final Motor Torque
