Picked up a Powerboost, coils and deavers?
matthewL600
Matthew
Lousiana
2021 F150 Lariat
camera operator
Hey everyone !
Picked up a 2021 lariat 6.5 bed 502A.
2 main reasons for this truck. Horse stuff / occasional tow / a bit of long highway commuting.
I do want to level this thing though.
Are the fox 2” Coilovers in the front the way to go?
for the rear end when I had a 2020 Raptor we always went with +2 deavers. Is that the consensus as well here ? Approx trailer weight is 5000-6000 pounds.
Also with a level what size tire can I accommodate? Do I need to jump to a +12/14 offset?
im not super interested in cutting the sub frame for a lift at this time.
honda250xtitan
Phoenix
2023 F150 XL Rattler
raptor spec deavers for towing sounds like a bad idea. tow with it stock first and see what you wanna do.
NitroDarwin
Darwin
Indiana, USA
21' F150 XLT
Manufacturer
For setups to level the front, it's up to you, if you've had Fox and enjoyed their performance then get fox coilovers. I dont think there is a bad option out of the known brands (Fox, Bilstein, King, Eibach....).I installed Eibach coils on the front of my 21' to level it out and keep it close to factory ride. If you were really wanting to lift your truck but was being detoured by having to cut, Rough Country recently came out with a 4in no cut lift.
As far as max tire size, what I've gathered from my research is 35" will fit w/ level. Rubbing will depend on tire width and offset. I plan on installing 285/75R18, 34.8" height but 11.3" width on stock wheels.
As far as the rear and towing I'd consider helper air bags to level when trailer is attached but little/no effect to the ride when not.
