PB IPC setting shows “non-hybrid”
Mosey
2021 F-150 Powerboost
Hi all, while making some simple Forscan changes I came across an odd setting in the IPC module (see attached photo). The setting named “Powertrain Hybrid” is set to “non-hybrid” which I find odd.
Can someone with a PB confirm if they have the same setting? My truck is functioning fine as is so I don’t know if this setting is even used.
Thanks.
Ford F-150 PB IPC setting shows “non-hybrid” IMG_0221
Porpoise Hork
Bret
IT Sys Admin
Just checked this and mine is set to the same thing. I've noticed it before and thought it odd but I also remember seeing it set as a hybrid in another module. Seeing as it does it's hybrid things correctly I never messed with it. lol
