SALEEN961
- Joined
- Jan 1, 2023
- Threads
- 12
- Messages
- 653
- Reaction score
- 876
- Location
- Radnor, PA
- Vehicles
- 2021 F150 XLT 302A
- Occupation
- Automotive Technician
My truck recently started throwing a P0430 code. When I cleared the code, it would routinely come back within one or two days. This happened across multiple tanks of fuel from different stations, so I knew that bad fuel wasn't the issue. I also know that my 25,000 mile truck has no maintenance issues, misfires, or oil consumption that would cause a catalyst failure, so there is no good reason for a catalyst to have actually failed.
I decided to run an induction service on my truck with about 32oz of water, followed by a polyetheramine based induction cleaner. Once that was done, I took my truck through a couple 1 hour catalyst reconditioning drive cycles where I would alternate between cruising at 70mph, aggressively accelerating from 30mph to 70mph, and coasting from 70mph to 60mph. In the end, no parts had to be replaced.
Here are the scan tool readings I had when the P0430 code was constantly returning:
Here are the scan tool readings after the induction service and drive cycles:
