Anyone have this happen? Went out to my truck at lunch and there is no sound out of the front left speaker (woofer or tweeter). This is the base XLT audio system. I'd like to avoid a trip to the dealer, but it seems like a head unit issue.
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.Anyone have this happen? Went out to my truck at lunch and there is no sound out of the front left speaker (woofer or tweeter). This is the base XLT audio system. I'd like to avoid a trip to the dealer, but it seems like a head unit issue.
I'm seeing the rear driver's door speaker doing this on an 8-speaker B&O - sometimes it works, sometimes it doesn't. If I park the truck and go back to it later it usually works again. It seems like an amp or DSP thing, so I'm wondering if you see any codes or updates - 1FTFW1ED0PFD04544With your VIN, I can check and DTC codes your truck is recording.
No OTA in queue and no relevant DTC codes being reported by your truck. Maybe a loose connection at the speaker?I'm seeing the rear driver's door speaker doing this on an 8-speaker B&O - sometimes it works, sometimes it doesn't. If I park the truck and go back to it later it usually works again. It seems like an amp or DSP thing, so I'm wondering if you see any codes or updates - 1FTFW1ED0PFD04544
Thanks!
Thanks!No OTA in queue and no relevant DTC codes being reported by your truck. Maybe a loose connection at the speaker?
Yea, that is mighty strange. Unfortunately, I don't see anything with what I have that can help you pin-point the problem.Thanks!
I actually pulled the door panel off and checked that. Everything's connected perfectly and the wiring looks to be in good shape without any kinks or anything. It's weird, it'll have no sound for one drive then I'll park the truck and come back and it works fine for the next drive.
