JExpedition07
- First Name
- James
- Joined
- Feb 14, 2023
- Threads
- 68
- Messages
- 2,126
- Reaction score
- 3,664
- Location
- Buffalo NY
- Vehicles
- 2023 F-150 STX 5.0L V8
When I replaced the timing chains, camphasers, oil pump, tensioners and guides in my 5.4 3V I filled the gerator housing with fresh oil and put the backer plate back on the pump. Before starting the engine to protect the new chain guides from a slapping chain you needed to pressurize the chain tensioners. These are tensioned by oil pressure. It took a solid minute of foot to the floor (doesn’t allow truck to start) cranking before the oil pump finally primed. I thought I was going to need to pull it back apart. The OE pump provides around 25 psi at a hot idle, the replacement for around 30 psi. That truck is still running at 240k in my buddies hands.
