Ffdlt371
Hi all. I just did dinner updates today via FDRS.
I had an IPC, BCM, PCM and ABS.
I didn't then in this order, PCM, ABS, IPC and BCM.
All installed fine until I got to the BCM. It seemed to be going fine and when it got to the final configuration, it said it failed. I got nervous and powered down the truck like it told me to do. I then tried the configuration a few more times because each timer it didn't succeed, it asked if I want to try again. I finally gave up.
Here's the interesting part. After the final fail, I powered down and shut FDRS. I disconnected my mongoose and started the truck back up like normal. It started and everything seemed ok. I went back and connected my cable and started FDRS. I let it do the module scan as normal. This was key on, engine off.
The weird part, no errors. All modules checked ok and no DTC's. I don't get it. Also, the BCM update is gone. I expected the others to be gone but not the BCM.
Any ideas on this? Maybe it did succeed and the software had an issue? I also drove it afterwards and all is well. No issues. I don't know what was in the updates, but I don't see any visual differences in the panel cluster or anywhere else.
Confused to say the least......
