fxxkintallguy
- First Name
- Kyle
- Joined
- Mar 16, 2021
- Threads
- 16
- Messages
- 53
- Reaction score
- 34
- Location
- Los Angeles, CA
- Website
- www.instagram.com
- Vehicles
- 2021 F-150 XLT FX4 5.0L 302A 5.5 SB
So I bought some used Raptor LEDs and the BoostedGreyGoose harness for this conversion. I needed to buy a few other things from Ford to make this conversion happen since the Raptor LEDs didnt have the BLIS bracket or wiring. My halogens had an 8-pin grey connector and a 4-pin blue connector inside, and I needed the 12-pin black connected and 6-pin blue connector inside:
726-44-02 (rear bulb outage)/ 00XX-XXXX-XXXX works as intended
726-43-02 (stop-position-turn config with build-out monitoring) / 0102-02XX-XXXX makes my right tail blinker not work when on the brakes, hyper blinking on right turn signal on the dash, but left one works fine with no issues when parked and engine off. When driving, hyper blinking occurs on both left and right turn signals in the dash, but not on the light.
And 726-43-01 (stop-position-turn logic for raptor tails) / XXXX-XXXX-01XX made it so the turn signals don’t flash when I’m on the brakes, and hyper blinking on the dash for both turn signals.
***At no point did the turn signals have any hyper blinking externally on the tail lights themselves.
Right now I only have 726-44-02 (rear bulb outage)/ 00XX-XXXX-XXXX activated because that’s the only thing that allows the turn signals to work when I’m on the brakes.
Any help is greatly appreciated!
- Bracket. Rear Right. Right.2021-23.: Part Number: ML3Z14D189N
- Bracket. Left.2021-23. Rear Left.: Part Number: ML3Z14D189P
- Blind spot radar wire. Socket Assembly (x2): Part Number: ML3Z13410C
