Mystery Trailer Brake System Fault
Str8Shooter
Maryland
Retired Systems Integrator
Received a Trailer Brake System Fault message for the 1st time today immediately after starting the truck at 3007 miles (I snapped the below picture as soon as I saw it). Never had a trailer connected since I have owned the truck. Happened 3 times in a row and even saw it again after a short test drive. The fault message eventually went away after a couple times driving it, but there is a related code stored on the truck. According to my BlueDriver OBD2 Code Scanner I have 1 Anti-Lock Brake Module code U0253-00 - which is noted as a confirmed status of Lost Communication with Accessory Protocol Interface Module (No Sub Type Information). For MIL Status for Anti-Lock Brake Module code U0253-00 it states the fault cleared at 3014 miles.
I was also surprised to find another code stored on the truck and I am not sure if it is related. The other code is C1001-01. According to my code scanner it states that there was a confirmed status of a Vision System Camera General Electrical Failure. The reason why I am surprised to see this code is because I never noticed any camera problems. Worth mentioning is that this MIL Status for Vision System Camera General Electrical Failure code C1001-01 cleared at 878 miles.
Questions I have are:
1. Should I worry about taking the truck to the dealer since the codes cleared on their own? What will a dealer do when they see codes magically cleared on the MIL Status? Am I going to be wasting my time with the dealer saying everything works fine?....because according to the system, it now shows all the codes cleared on there own.
2. Anyone have these issues?
3. Are there related TSB's?
Ford F-150 Mystery Trailer Brake System Fault 559A6E5E-79BF-4A1B-98CD-67372F6D3F54
Ford F-150 Mystery Trailer Brake System Fault Screen Shot 2021-12-18 at 12.57.59 PM
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hi there! send a private message to us with your VIN and the name location of your Ford dealership. I’ll look into this for you. Thank you!
Str8Shooter
Str8Shooter
Maryland
Thanks! I just PM'd the information that you requested.
Str8Shooter
Str8Shooter
Maryland
Just a quick update:
1. I haven't seen the Trailer Brake System Fault Message pop up on my instrument cluster in the last 10 days since I saw it first appear. I answered a couple private messages from Ford asking for information, some that I already provided in my original post. I haven't received any official response from Ford on what to do.
2. I found some TSB's on my own searching the NHTSA web site for the trouble codes stored on my truck. Here they are:
Ford F-150 Mystery Trailer Brake System Fault Screen Shot 2021-12-23 at 10.31.26 PM
Ford F-150 Mystery Trailer Brake System Fault Screen Shot 2021-12-23 at 10.37.38 PM
Joshua_Tree
Josh
Austin
2021 F-150 PowerBoost
Design
i am also having the trailer brake controller not working issue. Can you tell me is anything comes up from my VIN?
Lost trailer brakes half way down a snowy mountain pass last week pulling my Airstream. Talk about scary (and dangerous)
1FTFW1ED6MFA99761
El Amigo
Aris
2021 F-150 Limited
Manufacturing (ODM)
Can you please confirm how did you fixed the two codes?
Str8Shooter
Str8Shooter
Maryland
The Trailer Brake System Fault message is still a possible mystery. I haven't noticed any issues or dash alerts since the day I received the Trailer Brake System Fault message (just over 3000 miles). I didn't fix anything and I'm not sure if anything is wrong because I have never towed...I plan to read the codes again after the planned June 2022 OTA update.
As far as the Vision System Camera General Electrical Failure code... I never saw a dash alert. I only saw the code stored on the computer when I used my OBD2 scanner. I will speculate that it may have been related to when I installed my BedRug. When I installed the BedRug I pulled my tail light and disconnected the tailgate wiring harness to access the Bed LED and switch for a clean install...The camera wiring may be on the same wiring harness, but I'm not sure though. I think I installed the Bedrug at around the same milage that it cleared (878 miles) when the vision system camera code triggered.
El Amigo
Aris
2021 F-150 Limited
Manufacturing (ODM)
@Str8Shooter, thanks for the feedback I have same DTCs as you. What are the improvements on June 2022 OTA though? I haven't receive any OTA yet. Mine is 8/21 build
Str8Shooter
Str8Shooter
Maryland
For the June 2022 OTA, I was reading directly from TSB that I posted in post #4 above. That's where the OTA date came from and that is all I know.
That's interesting that you also have the other fault code for the Vision System. Did you ever disconnect any wiring harnesses? The only other thing that I can possibly remember doing around the time that code cleared was pushing the fuses located under the hood in further. Anyway, like I said in my 1st post, I never noticed any camera problems ever on my truck, and was surprised to see that code stored in memory.
El Amigo
Aris
2021 F-150 Limited
Manufacturing (ODM)
sorry I missed that OTA.
I have Sprayed Bed at Factory, probably they'd disconnected as well. Same as you all my 360 cam works well.
bward02
Castle Rock, Colorado
2022 F150 S-Crew Powerboost
I'm having the same issue. I went out and started the truck today and got this fault. My only guess is we had quite a bit of snow the last couple of days. Maybe something got wet? Mine isn't showing any DTC codes in Forscan. Does anyone have any ideas about this?
I also am getting a "reverse brake assist not available - see manual" message as well. I'm wondering if they are related.
Thank you
bward02
Thank you
Well the trailer fault cleared and I noticed I do in fact have that vision code stored. I haven’t installed anything except a backflip cover. Bed rug comes next week. Still having the reverse brake assist error though. Who knows what’s causing this gremlin with our trucks
