Running tests on the 'easy' battery solution I'm working on -- it's the first time I had a meter on / visible directly connected while getting into and out of the drivers seat. Ford's logic is so strange. Engine on - in driver seat w/ door closed, voltage charging. Door open, in seat, consume 12v. Any other condition than sitting in driver seat w/ door closed, consume voltage. Sit in driver seat w/ door closed, charge voltage. I put the truck back to stock battery config to test this simply swapping over the negative lead to the test LFP unit. Here's an example. @Snakebitten does your little app show you live voltage? Give this a try.
