Low Beam LED burned out. Replacement suggestions?
Ross
Ross
St. Louis
2023 F150 XLT 2.7L SuperCrew
2023 XLT, purchased used. One of my low beam bulbs burned out. The bulb is LED, but I can't tell if the truck came with LED or if they are aftermarket. I'm guessing aftermarket. I see a lot of aftermarket LED's, but have no idea what's a good brand. I'm not set on LED, should I just replace them with H11 Halogen? O'Reilly and AutoZone online says the H11 isn't compatible with my truck, don't know why that is. I would've never guessed that getting the right bulb would be so confusing.
Thanks in advance!
Ross
Ross
St. Louis
Thank you. I did check that too, and was still confused. :)
JohnTrigger
MD
‘24 F-150 STX 2.7L SCREW
Yeah,
XLT “optional” listed both for H11 and LED.
FORDTEXAS
2022 F150 LARIAT
Thanks in advance!
upload a picture so we can see what you’re working with.
Ross
Ross
St. Louis
I noticed that some of the LED bulbs state they aren't DOT legal for anything other than fog lights or Powersports.
Ford F-150 Low Beam LED burned out. Replacement suggestions? IMG_0253
Mosey
2021 F-150 Powerboost
Those are aftermarket. You should consider that a good thing as it can be replaced. If your XLT had factory LEDs it would cost you $$$$$.
Ross
Ross
St. Louis
I was thinking that would be the case since the manual says LED aren't serviceable.
Porpoise Hork
Bret
IT Sys Admin
They aren't. Had the passenger side quad LED fail internally on mine about a month ago. This took out the LED ballast in the process. Only the turn signal and cornering lamp worked. Since you can get the ballast fairly easily I swapped the ballast from the driver's side to it confirm the ballast had failed and the headlight burned that one out too. Took it to the dealer to get repaired with my Ford premium care ESP with LED coverage. My out of pocket was just the $100 deductible but the total cost of repair would have been $5400 for two new headlights, ballasts, diagnostics, and labor w/o warranty.
Cost of ESP plan 1800 through Granger Ford. Worth every penny.
Ross
Ross
St. Louis
Dang! Planning to do ESP through Granger by the end of the year - assuming ESP costs will go up next year. I'm still under the 3/36 warranty until July, so holding out a bit longer since ESP starts when you purchase.
Porpoise Hork
Bret
IT Sys Admin
I got mine when there was about 3 months left in the 3/36. What I didn't know is Ford Premium Care ESP coverage for new vehicles (still under factory warranty) always begins the day you first took delivery and the odometer was at zero. This is regardless of when you actually purchase the plan.
So yeah I'd wait till the day after the factory 3/36 has expired to get it if you want the most out of it.
Haulinday
Dave
Georgia
2016 F150 XL SUPERCAB 2006 FORD MUSTANG GT 2018 Ford Explorer XLT
Retired Machinist
That’s good to know thank you. About to pick up my 25 soon and was undecided on buying warranty
FORDTEXAS
2022 F150 LARIAT
Thanks in advance!
stick with VLED or @Diode Dynamics if possible.
those 2 companies make good stuff and are reputable.
ragu2
Southern Florida
2024 F150 King Ranch 4x4, PB, Hybrid
If changing out the blown out side with new led or halogen that side will be brighter than the other side being used longer and not new.
That’s what happened to me with my led headlight on my 2014 F150 Platinum.
Just an FYI
