license plate light bulbs
stlgrym3
SoCal
2023 F150 PB Lariat
anyone upgrade their dim looking license plate bulbs to LED? if so, need some recommendations.
Kodiak
stlgrym3
SoCal
2023 F150 PB Lariat
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
i bought a bag of 12 for very little money at amazon
i keep the bag in the truck just in case they go teets up
Graygoose2021
Oklahoma
Sales
Yes sir, and also got cab lights, they are bright! LOL
MJG44
Toronto
I just picked up Sylvania Superbright led from the local store. In stock, quick replacement.
Kodiak
thanks, is 194 the socket size?
I am not sure what the 194 signifies other than that is the type of bulb. Probably the socket but maybe others can say.
With that said a 194 bulb is common but you just need to make sure the bulb you buy does not sit higher or taller than the receptacle area. Some 194 LED bulbs can be taller than regular bulbs so you just need to be aware of this.
powerboatr
WEIMELTOY 194 Led Car Bulb 3030 Chipset 2SMD T10 194 168 W5W Led Wedge Light Bulb 1.5W 12V License Plate Courtesy Step Map Lights Trunk Lamp Clearance Lights (12pcs)
9.99 :love: :love:
amazon
RcFlyer330
Cameron
2022 F150 Limited Powerboost
In my 22 I went with the Diode Dynamics 194 SMD2 LED bulbs, cool white 6000k color temperature, and 24 lumens for the license plate.
I will warn you that whatever bulb you choose to use be aware if they are really bright (lumen wise) they will cause a bright spot and reduce the view of your backup camera at night. the bulbs I posted above do this but its not to bad. I also bought the DD 194 HP3 bulbs in the same color only 54 lumens and they where too bright for me.
Bought these, pretty much same light output if not slightly more. Works great. Went through some other vehicles and swapped out dome lights with them. Current flow is directional so if you install them do so w/ the lights on to make sure +/- is right. You can pay a whole lot more but not really get it. 12 pack, $10
https://www.amazon.com/dp/B07GRVN7R6
Ranger621
2022 F150 Lariat 4x4
Buy them on Amazon. They're cheap, only takes 5 minutes to change them out.
