Leaking under truck normal?
surveyor
California
2022 PB
First-time F150 owner. PB 22 Limited.
Are these drip locations normal? 2 by rear exhaust, 2 under middle of truck.
This is while idling at a campsite yesterday, while ProPowering a trailer at about 1 kW. Moderate/temperate weather.
Attached photo. Video too big so here’s an iCloud link:
https://share.icloud.com/photos/0b0cOfAamTbr5EG3lCbQxzbHw
Ford F-150 Leaking under truck normal? IMG_6134
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
yes its condensation
bfastr
Bob
Nashville
2023 King Ranch 5.0 V8
my 5.0 drips in the same place under the center, its right under the muffler and is condensation. and tailpipe condensation is common too
Pedaldude
Arizona
My 5.0 leaves the equivalent in drips to the Shroud of Turin outlining the entire exhaust behind the cats when idling.
These new engines are insanely efficient even compared with ones from ten years ago when it comes to turning fuel hydrocarbons into less offensive compounds like H2O and others as byproducts of the combustion process.
SCTYDOG
Chuck
2010 Escape Hybrid, 2015 CMax Hybrid, 2003 T-Bird
Computer Forensic Examiner
My 22 PB drips water from exhaust system in same place. Perfectly normal.
surveyor
California
2022 PB
Thanks, everyone. FWIW, I'd been worried about coolant leaking since the truck has been repaired twice for coolant issues. This thread helped. Plus, I've been taking measurements, and I think all of the fluctuations in levels are caused by temp (ambient, engine). Sleeping better now.
patmulligan99
pat
massachusetts
f150 XLT 3.5 powerboost
Attorney
New ford owner here. I literally have the EXACT thing on mine. Def got worried but feeling better
Gros Ventre
Western Wyoming
Water is one of the combustion products. It is in the exhaust stream regardless. So where does that water come from? When the exhaust pipe is cold, it will condense that water. Since sulfuric acid (& other nasty stuff) is also one of the combustion products, putting weep holes along the exhaust pipe enables draining of the liquid. This reduces rot out of the exhaust piping. There is a good chance that if you're using the PPOB to power your campsite (& the exhaust stream reduced), the pipe may not fully heat up and the condensation could be nearly continuous.
patmulligan99
pat
massachusetts
Attorney
Yeah honestly even after I drive my muffler isn’t always hot
