Just changed Oil at 5K miles. Engine running so much quieter WOW !
TJSparky
WA
I changed my oil in my 21 F150 5.0l and used Valvoline 5w30 Extended Protection Full Synthetic and can't believe how much it quiet things down. At a stop light I had to keep looking at my RPM to see if it shut off or not. I have always been a Mobil One guy but heard good things about this Valvoline Extended and thought about giving it a try. I am super impressed for the price.
tony72cutlass's'
Tony
Halifax
Very interesting! Was this your first oil change from the factory stuff?
I have used the standard motor craft stuff for my 1K and 5k oil changes but have a couple gallons of Mobil 1 full synthetic id like to use up in 5-30
TJSparky
TJSparky
WA
I should have made that more clear. I did my first oil change at 1000 miles and used the regular recommended Motorcraft blended 5w30.
I hear ya, I have always been a Mobil One diehard for decades but this has really amazed me so far.
tony72cutlass's'
Tony
Halifax
my 5.0 liter is still loud after 2 oil changes
:D:D
I tried a bunch of 22’s on the lot a few months ago and they were as loud, if not louder than mine between 3000 and 4000 RPM.
I’m hoping the Mobil 1 I will swap in will yield an improvement!
tony72cutlass's'
Tony
Halifax
I’m gonna try the Mobil 1 this next time and if it doesn’t help I’ll see if I can get what you got, how’s it sound at 3200 RPM I’ve got a bit of resonance right now
FORDTEXAS
2022 F150 LARIAT
i’m not complaining though.. would rather listen to it than a damn Ecoboost (no offense).
93dpscoupe
Jonathan
Bruceville, Tx
01 GMC 1500, 93 Mustang LX SSP
Product Marketing
I thought I was crazy, glad to know I'm not alone. Didnt do the 1k change, but did first change on Monday at 5200. Used Motorcraft semi 5w30 and an FL500S. Noticeably quieter.
tony72cutlass's'
Tony
Halifax
I’m just wondering if it’s got something to do with the weird deactivatable rockers when it goes to V4.
Gros Ventre
Western Wyoming
If just changing the oil quieted down your engine... you got a bigger problem somewhere. Cut open the filter you removed and see if there's visible grindings, shards, or debris in it.
nrmedic
NC
2022 F150 PowerBoost 302A; 2023 Tacoma TRD Pro
I used to be to loyal M1 and their filters. Swapped to QSFS with Champ PH500XL filters. Truck is quiet now.
Csvt18
SE Michigan
2019 f150 SCEW (current), 2022 f150 (ordered)
I just did my first at 2500 miles. 5.0 motor. Sounds way quieter around 3-4000 rpm. Makes me think they under filled from factory or it was the break in period burn off of some oil.
capiche87
Tony
Louisiana
2023 F150 PB 701a 4x4; 1985 Ford Bronco II
Veterinarian
I have a 2018 5.0 and I was shocked how much smoother/quieter it ran with 93 octane. It’s pretty remarkable how these engines and adjust to the fuel.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
In my Audi prior to my F-150, I tried several different oils over the years and miles. Every oil had a slightly different idle sound with it. They were all high quality oils (Motul, Liqui-Moly, Total, and others) with the same viscosity, but some ran quieter than others.
540Ratblog?
I've been running QSFS too, and those that know me are a little shocked. I was pretty loyal to another oil for a few years.
I'm happy enough with it, but my Blackstone reports have shown a little lower viscosity after 3000 miles (my typical oil change interval) than I would have expected. But everything else looks great.
Supposedly a fantastic oil for antiwar characteristics. Fundamentally what matters most? :)
