Issue recalibrating IPMA with Forscan (vehicle conditions incorrect)
newdeal99
Tom
2021 F150 on order
My front camera has a fault that is breaking a bunch of features in my truck. There was a Ford document that said that the error I had the first thing to try is to reset the IPMA module and recalibrate it. I tried to do that and it reset fine, then I was going to calibrate it and I realized that it was going to cause a problem because I had my desktop computer plugged into the power plug in the garage and it wanted me to drive with the computer still plugged in. So I cancelled, plugged the computer into the power port in the truck and then tried again and now it won't get to the part where it wants to to press OK and start driving, it gives me a prompt, I press ok, but now it stops at 41% and then aborts and says vehicle conditions are incorrect. I am not sure why it is doing this. I tried resetting the module again with the computer plugged in to the garage outlet and then going back into it again but even with the computer plugged into the garage outlet I can't get the to the second prompt where I press ok and then start driving again, it keeps aborting telling me vehicle conditions are incorrect. Any idea why this is happening and how to solve it?
Typically its related to not following the prompts.
Make sure you pay close attention to ignition on engine off
Ive had a few people have this issue I remote in and they missed a prompt.
newdeal99
Tom
2021 F150 on order
well I did the follow the prompts ok the first time, then the second time I did as well but it wouldn't work and gave that error, then I tried resetting it again with the ignition on and the car running so that I could do the whole thing without unplugging the computer from power and it gave the same error. Then I tried again and was going to do the reset with the computer plugged into the wall and then the calibration with it plugged into the truck outlet but it gives the same error again
DO a fresh scan.. When your vin comes up in Forscan select no.
If not let me remote in to take a look.. not sure anything different I can do but worth looking
yes please
Ok, I use teamviewer.
I have a license so its free..
Message me with the info directly and ill log on and see if there is anything I can figure out.
BlackMamba
Salt Lake City, UT
2023 Ford F150 Tremor 402A
Hey. Was this issue resolved? I am having the same error. But my 360 cameras are working. However when I bought the vehicle they were not working at all. None of them. So before I purchased the dealer took it to a Ford Dealership. They said a camera needed to be replaced and I don't know what else they did but the vehicle came back with 360 working. After a few weeks of purchase I started using Forscan but honestly didn't notice the DTC code. It may have already been there. All the programming that I have done had nothing to do with IPMA.
I don't have any other dtc codes. I deleted a PCM DTC one after adjusting for my new tire sizes But I can't delete IPMA B1578:78-2F
newdeal99
Tom
2021 F150 on order
I don’t know of anything has changed with forscan but at the time I posted this the only way to get it working was to use a mongoose cable and fdrs because only fdrs could get it into whatever mode was needed to calibrate the lane keep camera
FirstFord
South Central Missouri
I have the exact same DTC. It was triggered after I swapped my "standard" power side view mirrors to power tow mirrors. The cameras in the tow mirrors are physically located in a different place than where they are in the standard mirrors - about a 3" difference. My 360 cameras worked fine before and after the swap, and I have no complaints about the image quality of the cameras after the swap (no stitching issues, etc), but it did trigger the B1578:78 DTC. I've been exploring this topic, and the best I am able to conclude is that my truck wants the mirrors to be realigned / re-calibrated (because they're in a different place now), and that seems to be the only way to get the DTC cleared. But from what I have been reading, A LOT of people have had problems and failures trying to perform this task.
