Is this a full kit required to upgrade to 12” screen in the 2022 xl ?
camps23
Ontario
2022 F-150 Tremor 400a
This is the dash I currently have, will the lower trim still work with mine ?
Ford F-150 Is this a full kit required to upgrade to 12” screen in the 2022 xl ? IMG_0652
rjinaz
Rick
AZ
2023 F-150 Platinum PowerBoost 701A
You do need the new lower panel as the audio controls are relocated to it when you go to a 12" screen.
You can pull the A/C controls from your existing panel and transfer them to the new one since most of the features on the new panel A/C controls won't work at all.
They'll look pretty but be mostly useless. Looks like your XL is 2WD, so transfer over your existing drive mode switch to the new panel as well. The 4A/E-Locker drive mode switch on the new unit won't work with your truck.
camps23
Ontario
Will I need to have the new 12” pcim programmed to my truck vin? Or just forscan updates ?
Big Dog Daddy
New Jersey
You'll need to have it programmed with your VIN.
I suggest contacting someone like @Jesse-Infotainment or @rugedraw for some guidance.
Ha.. you beat me to it! I was going to say the same thing. This doesn't work unless the modules are coded to the trucks vin, definitely not a plug and play proposition.
I know I can't help him do this, and due to a conflict of interest with his employer Jesse won't be able to either unless he buys the kit from him.
@camps23 I think I saw that same picture floating around a Facebook F150 group recently. Not sure if I commented on it or not, but you cannot just throuw random modules onto a truck like a mad scientist making Frankenstein. Correct part numbers and firmware on whatever module you put in is very important if you want to maintain the integrity of the module network and the data on Ford's servers. Putting in a wrong part with the wrong software can cause major programming problems in the future. There is a reason why these kits cost what the cost when you buy them from a reputable place like Infotainment.
$2600usd is an insane amount for this upgrade. How are the guys on YouTube doing it for $800 ?
Those guys have no idea the world of shit they made for themselves by taking shortcuts. Yea, you can throw the parts in there and in turns on and works. That doesn't mean there aren't underlying issues they don't know about. I'm not a software engineer. I lack the knowledge to tell explain to you why you can't use buy an APIM from ebay and throw it in there. All I know is that it is not that simple.
taylor-infotainment
Taylor
Oviedo, FL
Website
infotainment.com
17 Ford Fusion
Ford Sales Advisor
Let me try and explain. So the programming on these units is very specific. There are a lot of features on your Vin that we don't want you to lose as part of the upgrade. However if we program to your as-built data that will not work either as your as-built data does not have the upgraded radio present. Essientially what we are doing is ensuring your Vin data is programmed into the APIM so all of your features work and then hand programming in the features associated with the new radio. Then we test the screen and module together so we know you are getting a quality unit and failure is much less likely. My name is Taylor with Infotainment and if you have any specific questions I should be able to help!
