Integrated Trailer Relay Module OTA Update
FirstTimeFord
Had this pop up today when I pulled into my garage and turned the truck off. Just passing along. 25 Platinum
Edit: The update completed. Weird, I received a notification from Ford Pass that a door was open when it woke the truck up to complete the update. Woke me up, went to garage, the truck DRL's were on, a little spooky. Back to bed.
Ford F-150 Integrated Trailer Relay Module OTA Update 1000019609
Ford F-150 Integrated Trailer Relay Module OTA Update 1000019581
Ford F-150 Integrated Trailer Relay Module OTA Update 1000019580
Patrick
Central Texas
2025 F150 Supercrew FX4
SOCC Operator/Mgr. Tx Elec Grid
Weird, I got a 25 Lariat hi loaded, got that same message but having an issue with rolling up drivers windows since. It will reach top and back open like it hit an obstruction?? Wasn't rolling down completely either, now it goes down but doesn't stay closed with reversing back down. I haven't tried reading up on it until now
FirstTimeFord
FirstTimeFord
Wild, I just had the same issue with my passenger window today.
EDIT: This ended up working for me.
molsonrocks
2024 F150 PB with 7.2kW Pro Power Onboard
Patrick
Central Texas
@FirstTimeFord @Hi-tech Redneck
I had the bounce back issue with my driver side window a little while back. Mine would bounce back right as the window got snug on the way up, so holding the button on the way as part of the reset up was not working for me.
I did get it sorted out though: https://www.f150gen14.com/forum/threads/request-vin-lookup-thread.13393/post-697505
Did you do the up button and hold 2 sec, down windows button and hold 2 sec then up one more time a d hold?
FirstTimeFord
FirstTimeFord
I believe this was the winning combo for me. I did auto down. Then auto up, hold 2 sec after it hit the top position. The window did bounce down but I just repeated the up and hold 2 sec at the top a few times. You can try manually getting it to the absolute top position then pressing up and hold for 2 sec too. The video was what made it make sense to me. Hope it works for you! I've had no issues since.
molsonrocks
Mine would not let me hold up for two seconds once the window was up. The second the window rolled all the way up it would bounce back.
So what I did was roll it up and hold, it would bounce back immediately down halfway, and I’d roll it up again and hold, it would bounce back immediately halfway, I’d roll it back up, etc. Did that maybe 6 times and it stopped the bounce back halfway. Hasn’t done it since.
FirstTimeFord
FirstTimeFord
Great! Glad to hear it! 👍
