RickBullotta
Rick
Pennsylvania
2021 F-150 Lariat Powerboost
Just a quick follow up on this. Purchased a pair of 5100's with the goal of settling down the rear end on my 2021 PB, which hopped like a tweaker getting tased whenever you hit railroad tracks, big road seams, etc...
I had planned for a one man, one beer installation, based on the various install videos I had watched. Unfortunately, on my 4WD PB which came stock with FX4 shocks, the length of the Bilsteins with the retaining band on them was about 2" too long. I double checked the part # - that was correct. Wrangling them into position and getting the lower bolt through was a b*tch, but after about a dozen times re-compressing the shocks (which ain't easy when you're on your back scrunched under the truck), I finally got it all back together, torqued up and ready to go. All told took about an hour instead of the 20 minutes I planned. I rewarded myself with two more beers.
Took it out for a test drive on a stretch of road that always gets the rear end jumping and it was WAAAAAAAY more settled down.
I highly recommend this mod - best $200 I spent on the truck thus far.
Buyer2021
central TX
retired!
Now if you want a really nice ride, install the front 5100's at stock height. ;)
Best $480 I spent on my truck (4-corner 5100 bundle from Stage 3 Motorsport with forum member discount). (y)
Yeah, that was a six-pack install spread over 2 days :D
Tip - if you jack the rear a bit those shocks slip-in easy without compression struggles (use jackstands for safety!).
LouDog
Sean
Grand Junction CO
21’ Lariat Powerboost
im thinking about doing them same. Any plans to do the fronts now?
Buyer2021
central TX
retired!
Mosey
2021 F-150 Powerboost
I would love to do a 4 corner swap, but the fronts look way too daunting for me.
RickBullotta
RickBullotta
Rick
Pennsylvania
Not for now. I want to maintain stock rake/height so will consider the various options. I had Fox 2.0's on the front and rear and took them off.
Buyer2021
central TX
retired!
For sure you gotta go with your capabilities & comfort level. It is a bit of a job and having the proper tools (including Workshop Manual for torques, etc) helps a lot.
Post about my installation.
Gord0
Gordon
2021 Lariat 502a
The fronts aren't too bad. There's multiple ways if doing them. Some faster, some slower, some easier. I've done fronts a few times on different f150's. The 6112's on this truck took me about 2.5hrs with having to swap the spring hats over. Totally different truck after swapping the stock FX4 for 6112/5160 combo.
Ricksc
Rick
Bay area
I got the 6112’s fully assembled for an extra 100 bucks. Save more than that in time and labor. Had them installed. If you do them yourself there’s like 10 nuts Ford says are 1 time use. The new hardware doesn’t include these.
dmac
Gearhead!
It is crazy how underdamped the powerboost is.
With 5100s all the way around on a platinum powerboost, it still feels less in control than an XLT crew cab FX4 V8, with only Bilstein 4600s in the rear. Batteries + platinum junk is heavy.
Don't get me wrong, the 5100s are MILES better than stock.
Big Dog Daddy
New Jersey
Great job! Rick, cheers to your persistent effort. ?
Nice to hear it improved the ride. Sway bar next?
Ford F-150 Installed Bilstein 5100s on 2021 F-150 PowerBoost 20240619_180755
GypsyDanger
Jamie
Cleveland, OH, USA
22' XLT
Electrician
i did the rear 5100s on mine last weekend and now im contemplating the fronts. might jump up to the 6112s if it makes the install faster and a better package. Im sticking to stock height.
Gord0
Gordon
2021 Lariat 502a
If you buy the 6112's from shock surplus pre assembled it makes it a little quicker and easier.
GypsyDanger
Jamie
Cleveland, OH, USA
22' XLT
Electrician
hell yea ill check them out! thank you!
