dspa
- First Name
- Dustin
- Joined
- May 11, 2023
- Threads
- 14
- Messages
- 102
- Reaction score
- 40
- Location
- New Mexico
- Vehicles
- 2024 F-350 SRW CCSB Platinum
- Occupation
- IT Analyst
Hi All,
As the title suggests, I'm in the middle of installing the Icon 91823C kit on my truck.
I managed to damage the boot on the upper ball joint. It's probably one of the stupidest mistakes I've ever made working on a vehicle, and totally my fault for getting into a hurry. It'll be 2 days until the replacement control arm gets here (no serviceable ball joints up top), so I decided to go ahead and do some test fitting while I wait.
Firstly, despite what Icon says, it is basically impossible to adjust the preload of these without compressing the spring. I saw information in videos that made it look like it could be done, and even Icon themselves said it could be done when I called them, but it cannot. The spanner is stretching/ovaling the holes on the threaded mount. My "widowmaker" spring compressor is too bulky to fit between the coil and the shock tube, so I'm looking for an alternative tool. Best I can find locally that may do the job is the PowerBuilt 641429T that AutoZone sells. I'm hoping it'll fit around the 2.5" shock tube. I'll know tomorrow.
Secondly, and the main point of this thread... has anyone who has installed these noticed that the supplied hardware is sort of small and doesn't seem to be the right size to fit the mounting holes, top and bottom? The top mount holes are a bit wider than the supplied bolts, and slotted. I understand they are slotted for alignment purposes, but the side-to-side play seems like an awful lot. Icon doesn't even provide flat washers for up there... just split locks. Looking toward the LCA, the lower bolts, 7/16", are positively swallowed by the holes in the lower control arm (pictures provided).
None of this really gives me warm fuzzies for a tight, secure installation. Does anyone who's done this have any thoughts on this? The stock coilovers have a taper on the bolt that goes into the control arm to center the coilover's lower mount. Nothing like that with these.
I may just be overthinking this... it's been a bad shop afternoon. But I want to make sure I'm ready to go, mentally and physically, when the replacement control arm gets here.
Thanks!
Dustin
Thanks!
Dustin
