How to Remove 7 Pin Connector
Kmc0929
Korry
North Carolina
2021 F150 Lariat Powerboost
I need to remove this to add an auxiliary reverse light. On my 2016 it was easy to remove, however on my 2021 im not sure how to remove this. I dont want to break the plastic tab, any idea how to manipulate this thing?
Ford F-150 How to Remove 7 Pin Connector IMG_3314
DT444T
Jake
21 AMB Powerboost Lariat
Meat servo
I believe you need to PULL the gray tab out to "unock" the push-tab. It's a two-stage affair.
DcnPat
Patrick
Alexandria, VA
2016 Jeep Wrangler 2022 Subaru Outback
IT
Make it easier on yourself. Release the entire trailer connector (the metal clips on the side) so the 7 & 12 pin can be pushed out then you don't have to work from under the truck. You should be able to figure out the 7 pin connection release then.
B-real
Utah
2023 F150 Tremor 3.5
This. Did it just a month ago. Squeeze the metal clips on the sides of the entire connector and push it out.
Heavishot
Kerry
DFW, TX
2021 Platinum F-150
I’ve released the entire connector from the bumper but I COULD NOT budge the 7 pin harness from the back of the connector. Finally figured out after you remove the gray tab you have to push in on the black tab while you pull the harness out.
Ford F-150 How to Remove 7 Pin Connector IMG_0825
JoshFed
Alaska
2019 Ford F250
Did you have any issues putting the connector back in the bumper? Mine won't lock in. It's like I can't push the connector in far enough for the metal clips to engage.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
Applied dielectric grease to the pins before you reconnect it. It will add a little bit of waterproofing and prevent some water intrusion.
