Tlusk7
- #121
You can easily test the coax by taking the front cam coax at the IPMA and moving it to port 2 where the rear cam goes. If the front camera shows picture when in reverse then the coax is good. This DOES NOT verify the camera is the correct one though. If you can do this and it works, but not with the front and rear cam plugged in at the same time then there is a compatibility issue with the cameras. Coax either works or it doesn’t.Still working on it. I was waiting for the "CBA" jumper between C316 and C1591. I have a duplicate set of coax and was tired of messing with my installed version. I have two extra ML3Z-19G490-BC cameras and one ML3Z-19G490-BB camera. When I did some initial testing the "BB" camera connected in as the front camera resulted in a washed out picture (although it is a washed out rear view). I just got the jumper today and will test over the weekend. I should have enough parts to isolate the issue or at least give you and @Jesse-Infotainment more information about what I am seeing. I've been running wires for front radar, cargo camera, etc.
