How Do I Stop All The Automated Lighting?
Tom
Midwest
2021 F150 Lariat, Hybrid, Dbl cab, short bed
Retired educator
I can understand that it would be nice to have my vehicle's exterior lights come on as I approach it at night on the street, or in a lot. However the continual on/off--on/off gets rather annoying while I am working in my garage.
How can I disable that feature?
Thanks
AutonomousHybridF150
Kristopher
Pensacola Fl
2021 F150 Powerboost
Adjuster
Take the key out of your pocket when you are in the garage.
or put the 2nd key inside your truck.
Tom
Midwest
Retired educator
I understand that leaving the key elsewhere, instead of in my pocket, soles the problem. But then that creates other inconveniences.
I am not sure I understand the logic behind the idea of leaving the "2nd key" in the truck. I understand how it would prevent the lights on/lights off annoyance, but then I have to remember not to leave the key in there.
xtraman122
Pete
MA
‘24 303A PB
I thought you could, check through the settings for anything related to “Approach Lighting” and/or Zone Lighting and disable all those and you might be able to get rid of it.
Papawsnow
Elliott
IN
2021 Lariat FX4
Pretty certain you can turn it off in the settings, but I can’t check exactly where at the moment.
jeffcrum
Lake Saint Louis, MO
Computer programmer
You can't have it all. You can turn them off in the settings. But, that is another inconvenience to do that and turn them back on.
There is no setting for ... Only do it when I want.
Jus Cruisin
Tim
Metro Detroit
Very retired
When I'm working around the house/garage I don't carry any keys. When I'm pulling the truck outside to wash it for instance I just set my key fob on my workbench. I just grab them once I'm fixing to pull it back in.
Harlemox
California
2021 F-150 PB Platinum
What you're describing is the "Approach Lighting" feature which can be disabled through the Settings menu.
I turned mine off (in conjunction with my power running boards) because it was annoying to have the power running boards/lights deploy any time I walked near the truck.
ZWARRIOR
California
Software Engineer
awwww I always think of it as my truck saying hello.
Tom
Midwest
Retired educator
Got it!
Harlemax: Thanks, You did send me down the right path, but I took a different fork, and it worked.
Settings
Vehicle
Ambient Lighting: Choose "WELCOME LIGHTING" On/ or Off
Choosing "Off" did the trick.
