Hard shift problems *solution*
Missmy3/4ton
Midwest
300a XLT 5.0 4x4
If you reset adaptive shift strategy, Ford says it’s very important that you follow the reset procedure closely. Which involves accelerating and decelerating several times. I’d have to look up exactly how it tells you, but just resetting it and the driving like a grandma isn’t going to be a lasting fix.
Did you ever find this procedure?
EatDirtFartDust
Josh
St Louis, MO
2021 Ford F-150 XLT, 2015 Lincoln MKZ
Ford service manager
Thanks! Very interesting they want you to do the shift cycle 7 times in total. Seems like a pretty easy process overall.
As long as you can find a stretch of road to do it on without pissing other drivers off.
3DogKnight
Minnesota
100% retired
Has anyone notice that the temperature gauge for there transmission is a quarter high. My 2015 always had it in the middle and I’m just wondering if this is normal for my 21
Mine is right in the middle when warmed up but takes a long time to get there.
Nighsight
Tim
N. Cal
2021 F150 Powerboost
There is a TSB for updating the PCM software to fix the 1-3 shift. I posted it in the powerboost forum.
joeysd_socal
Joey
La Vernia, TX
2018 Ford F-150
Oil & Gas
If you have been a victim of your truck shifting hard or lurching in any gears it is probably due to the truck being “hot rodded” or accelerating hard right off the transportation truck. Not uncommon for a dealer to test out the “first of its kind” when it comes to power and performance. My truck being the first powerboost to hit the ground in nw florida it had a good bit of miles on it. (60)
from day one I have experienced hard shift from 1-3 and from 4-5. The other day using forscan, I was able to “reset” the shift learning pattern. I will add screen shots later of what the actual page looks like.
I have not had a bad shift since I reset the module. Looks like problems solved. Roughly 600 miles since the reset.
Hello sir. I’m new to the forum and have the same issue with my ‘18 F-150 5.0. Will the forscan device you mentioned work on my model? If so, do you have a product link or model for your forscan device?
Thank you.
MonkeySpank
Rich
Hawaii
2021 F150 XLT 5.0
This worked for a few months, looks like the hard downshift from 5 returned for me. :unsure:
