Had questions about pinion shims 2025 rcsb 4x4
ateks5.0
ateks
arizona
ford f150 rcsb 5.0 4x4 2025
New to the ford stuff Thinking of removing rear lift blocks from factory and adding some 1” shackles it’s a 4x4 rcsb 2025 so didn’t know what shims to get took a gamble order 2.5 shim and 2wd bump stops, ubolts hardware etc from ford. But if u had any input of what else i should get or what shims i should go for let me know thanks.
Ford F-150 Had questions about pinion shims 2025 rcsb 4x4 IMG_5063
mancrab
WA
2025 F-150 RCSB
How did this end up working out for you, was considering doing the same thing and just buying shims before I know exactly what degree, did you install everything? Did it work out well?
ateks5.0
ateks
arizona
Also 2.5• shims but would recommend u get 2 and 2.5 to c what works best for u
ateks5.0
ateks
arizona
2wd bump stops , 2wd shocks and all. New hardware is key. Still feel a slight vibration around 80mph for half a sec then goes way but did remove the ugly factory rake. No alignment what so ever was needed, and it rides great like oem
ateks5.0
ateks
arizona
Also get 2wd ubolts all hardware as well even for the shackles n shocks torque specs on these are easily over 150+
mancrab
WA
2025 F-150 RCSB
Yah, the stock rake on these is crazy, i was thinking of lowering the rear like this, then getting adjustable front coilover to bring it closer to level, still haven't decided yet
ateks5.0
ateks
arizona
It really is also should check on your truck if your blocks come with a angle heard if not u don’t need shims but mine did so threw em on regardless
Tilstad
KJ
Tx
2025 F150 RCSB
Not directly relevant, but a reference nonetheless, I got 2.5 degree shims for a 2wd with a 1.5' lowering shackle.
CarbonMark
WA
2024 F-150 XL Regular Cab
On my 2024 RCBS 4x4 I installed Ford performance 1.5” drop shackles, removed the blocks, and installed SPC 2.5 degree shims.
The stock blocks did have taper built into them. Using the 2.5 degree shims kept the same pinion angle I had prior to modifications. You will install the shims with the fat edge rearward.
My goal was to reverse level the truck, which I got close to but still had a full inch of rake. Truck also rode better with more weight on the rear.
Buddy726
Joe
United state
2022 f150
Hi, I have a 2023 4x4 f150 that I want to level/lower. Same as everyone Iam thinking of removing the lift blocks and changing the rear shackles and doing some coils in the front, maybe using the Ford lowering kit not sure how good it is need to see more reviews but when I do what kid is the best one to use and if you remove the blocks, which shims do you need to use
Rinn69
N Central IOWA
Retired USAF Medic
@Buddy726 I've had the Ford lowering kit installed ($700) by a local dealer on my '24 since July of 2024 and have had no issues. I would recommend buying the SPC caster/camber alignment kit and have it installed with the lowering kit. The tech couldn't get the front alignment exact, but I didn't know about the SPC C/C kit until 6 months later after the install. I measured the pre and post install heights, and it was exactly as advertised-- 1.25" F, 2.5" R. It's not a lot, but definitely noticeable vs stock. It rides as good as or better than stock, even with 20x8.5 BAP wheels with 275/55/20 Toyo Proxes STIII's.
SPC kit --> https://www.steeda.com/spc-performa...nt-cambercaster-kit-f-150raptor-09-14_p_13998
Ford F-150 Had questions about pinion shims 2025 rcsb 4x4 Truck with spoiler
Buddy726
Joe
United state
2022 f150
Looks good thanks for you response and your time. I will look into it. P.s. what shocks did you uses?
Rinn69
N Central IOWA
Retired USAF Medic
Still on factory shocks.
