Gauge cluster help
Mas280
SF Bay Area
2023 F150 STX, 2023 Lightning
Today I upgraded my 2023 STX from the 8” to 12” display. I also added the nicer gauge cluster. Everything went Smooth but the only problem is the new gauge cluster has more miles than my truck. Forscan can only raise miles and not lower. What option are there to correct the odomete?
Thanks
Ford F-150 Gauge cluster help IMG_5203
Ford F-150 Gauge cluster help IMG_5204
Ford F-150 Gauge cluster help IMG_5208
I believe only dealers can do that with a lot of paperwork. To prevent fraud can only go up in miles since usually buying new unit with 0 miles.
Big Dog Daddy
New Jersey
You really don't want to do that. A cluster change with mileage change is a big red flag on car fax. Dealers don't want to see that. And people will avoid the truck on resale.
JJSnell
JJSnell
CdA, ID
2022 F150 Platinum FX4 PB
Anyway you can plug the old cluster back in and take a pic of it with a dated snapshot of a Carfax? Then take it to the dealer?
In an unrelated Question...
WTB 2022 PB Platinum dash cluster with less than 3,000 on it.
Im joking of course...
Only thing I can think of is you trade with someone else that has OVER the miles indicated for one with LESS miles than you have now, and they can increase odometer as needed and you do the same.
Otherwise put your old dash back in and run up the odometer under you exceed this new one?
As mentioned odometer fraud is a thing and frowned upon in the whole industry. You'd have to produce some documentation on old odometer and new odometer on swap and somehow register it. I know on vehicle titles in my state they have a box to check off incorrect odometer.
Really you are in for a lot of paperwork and might be better off buying a low miles dash and selling off what you have to recoup the money.
JGDallas
Jaideep
Frisco, TX
F150 STX
Self Employed
Thanks
Besides more miles on the new cluster, you have two other issues that are different than what your old cluster has. (1) different engine hours, and (2) different idling hours. I recently spoke to a guy in Houston TX who can fix this. It does involve opening up the new cluster, flashing the chipset to zero, and then using ForScan to program the miles, engine hours and idle hours to match your old cluster. You’ll ship your 12” digital cluster to him, he’ll fix/reprogram it and ship back to you. Don’t quote me on this…. I believe he said all this will be $250. I can give you his contact if you want. Bet there are guys who do the same where you live. Best 👍
rugedraw
Javier
Miami
Auto Sales
I doubt the dealer can help with this even if they wanted to. I doubt FDRS will even recognize that cluster since it is a different part number that what it was built with.
