Front Hitch for 2021 F150
wmuav8tor
Matt
SW Michigan
2021 F150 XLT
Airline Pilot
Any idea if the mounting holes are the same on the frame of a 2021 as a 2020 and older for a front hitch? Anyone install a front hitch on their 2021? So far I haven't found any websites that guarantee fitment on a 2021 F150. I'm assuming it will probably take some time for manufacturers to design one if the frame is different.
Not that there is any rush, I don't even have a VIN 6 weeks after placing my order ?
Mostly just use it for a cargo carrier or bike rack when towing my camper.
Hambone
Aaron
Idaho
2021 F150 XLT Sport, 2011 F150
Home Inspector
I've been looking into the same thing but unfortunately haven't come up with one yet. I need one to throw my dirt bike on when towing the trailer. Hopefully one comes available that does not hang down to low and fits "high and tight".
Pedaldude
Arizona
I just bought some receiver hitch stock off ebay, since I plan on welding something up.
The power airdam will indeed interfere with any underslung front hitch. Even if the frame is compatible with prior gen hitches.
I plan to mount mine right where the intercooler goes on the turbo trucks, since I have a V8, I looked underneath and there is plenty of room as well as several mounting possibilities.
My main reason will be for hauling 20’ sticks of steel tubing with a roofrack but it will also be a good option for a receiver mounted winch, bike rack, etc...
MnTom
Tom
Minneapolis
2021 King Ranch Powerboost
Good luck; I want a front hitch for maneuvering a travel trailer in my yard, will wait until the truck arrives, crawl under and see what I can weld up....
Pedaldude
Arizona
I ordered these off eBay, the 12” length was $20 and the pair of 6” ones were $25:
Ford F-150 Front Hitch for 2021 F150 BF6A9D49-7A7D-492B-B840-E780E085D274
The local steel supplier has blanks but they’re overpriced. I looked for unpainted but painted is fine. I will put up some pictures of underneath the truck next chance I get. I will probably make some measurements too.
REDDRUM55
Chesapeake Bay Virginia
2021 F150 STX 4X4
RETIRED
[/QUOTE
REDDRUM55
2021 F150 STX 4X4
RETIRED
Today, I installed the Curt #31083 front hitch. I removed the automatic air dam and motors. Trimmed a 4 X 1 inch slot in the center bottom edge of the outer dam. You need two people and a small screw jack to spread the arms slightly. It fits fine with 10 inches of road clearance to bottom of 2 in. tubing.
Andyc
Andrew
Sussex UK
14 Shelby Raptor. 05 AEV Jeep TJ4.6 SC. 21 Lariat
Business owner
If you get a chance, would be great to see some pictures of what it looks like installed.
Bigal323
Canada, ontario
I'm sure lots of us would like to know/see the outcome. If you have any pictures of the process...
....please.
Norris McCarty
Norris
San Angelo Texas
21 F150 Lariat 4x4 PB 7.2k FX4 17”Raptor Beadlocks
Own a RV dealership
Is your truck a Powerboost?
Sentinel1201
DFW
2021 F150 Powerboost
Any pictures? I am about to install a front hitch and then a hitch mounted winch. Curt says 5000lb rating, but Reese has one that says 9000 lbs straight pull rating.
Would love to see pics mounted. I ditched that silly air dam long ago so not worried about that.
