Front Differential/ Transfer Case Driveline LEAK
Platinum Peasant
West Sacramento
Dropped my truck today at the dealer for leaking differential fluid where the transfer case driveline enters the front differential. Fluid only leaked when any of the 4WD modes were engaged. Anyone experience this on their 14 gen? Just hoping it’s not months for parts!
Ford F-150 Front Differential/ Transfer Case Driveline LEAK CE7A66B6-2951-4039-8C52-3B9D428D9C8A
Ford F-150 Front Differential/ Transfer Case Driveline LEAK 09E2C577-CD37-401F-AE02-BE17131A6B68
Ford F-150 Front Differential/ Transfer Case Driveline LEAK 9F0712D8-529A-4D0F-BFF8-C7310DB7A243
Ford F-150 Front Differential/ Transfer Case Driveline LEAK A695A9EB-1F6A-4501-82BB-60CA7CB1660D
Ford F-150 Front Differential/ Transfer Case Driveline LEAK 3E322F67-CCE3-4FF6-A3B6-6099F6B32B40
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hi there! Can you send us a DM with more information? I’ll see how I can assist on my end. Thank you!
Spacedright
21 Lariat
Mike, was it just a bad seal? Mine is doing the same at 12k and I see a few others out there.
DennisG
Dennis
California
Had the same issue on my 2021. Bad seal. Mine started leaking at around 8.5k miles.
tony72cutlass's'
Tony
Halifax
Which seal was it? I’m guessing all 4x4 are susceptible to this leak?
Je1279
Jared
Upstate NY
I recently read a post from @Who are you where they were doing an oil change and noticed that their front differential was also leaking from the seal area. Hopefully, this was just a bad (or improperly installed) batch of seals rather than a larger concern.
ChrisM
Macon
2021 F-150 1996 F-150
Electronic Technician
I have a 21 XLT FX4 and local dealer noticed a leak on the rear differential. at 17k. They said it was a pinion seal and would have to order one. I tried multiple times to get the service performed and always some excuse. I took it back at 24K to get the oil changed and they said it wasn’t leaking. I heard a humming noise this past weekend so I took it to another dealership and they confirmed it is leaking and they are going to repair it in a couple of weeks. Never heard of so many reports of seals leaking on new vehicles. I’m done with the local dealership.
NICK_POWERBOOST21
Chicago
2021 F150 Powerboost
My 2021 powerboost started having a propane smell in the cab and found it was caused by the front differential leak. My dealer is working on the replacement. It`s a shame since it`s only 15k miles. Definitely a paper-quality part...
Azben
Az
2012, 2022:f150
Was yout smell all the time? Oddly I only have a smell in the cab when a window or roof is vented at lower speeds. I don't have any odor when when all windows are closed. My smell seems more like gear lube than propane.
